Tablets & eReaders Logo
A
Anonymous Posted on Sep 29, 2014
<!-- from fixya rte -->Reset apple id and create apassword? - iPad Apple Tablets & eReaders
Jesse Scarborough
Level 1:
New Friend:
Greenhorn:
A rookie expert who has answered 20 questions on their first day.
  • Contributor 20 Answers
  • Posted on Oct 01, 2014
Jesse Scarborough
Contributor
Level 1:
New Friend:
Greenhorn:
Answers
20
Questions
0
Helped
4122
Points
23
Go to iforgot.apple.com and it will lead you through the process. Apple My Apple ID
1 Related Answer
Jim Thomson
  • 1099 Answers
  • Posted on Feb 06, 2012
SOURCE: how to creat Apple ID for Ipade 2 16 gb
Go to https://appleid.apple.com/cgi-bin/WebObjects/MyAppleId.woa/
1helpful
CAN A IPAD GEN 2 ACTIVATION LOCK BE REMOVED FROM THE PREVIOUS OWNER WITHOUT LOCATING PREVIOUS OWNER TO UNLOCK?
Afraid not mate , depending on what iOS u have installed u can back up your device ( not in your case as screen needs to be unlocked ) plug Into PC hold top button and center button for 20 seconds while connected to iTunes and follow prompts
My sister forgot her Apple ID on her iPad and she's 55 and can't remember her password what to do?
Under this circumstance you may have to reset the iPad if you forget both Apple ID and its password.
To reset iPad without Apple ID, you need first put iPad into DFU mode and connect it to your iTunes. Your iTunes will help you to reset your iPad without entering Apple ID easily. Resetting your iPad with this method will result in wiping all the data in your tablet. The following steps will show you how to do that.
Step 1: Open iTunes on your computer and connect your iPad to the computer with a USB cable.
Step 2: After that, turn off you device. Press and hold the Home button for 3 seconds.
Step 3: Put your iPad into DFU mode: Press and hold the Power and Home button for 10 seconds. Then release the power button and keep holding the home button. When you see the Apple logo disappears, you have successfully put your iPad into DFU mode.
Step 4: When iTunes detects that your iPad is in recovery mode, you can restore it now.
Step 5: Click on Restore iPad. Then you will be notified after the reset and your iPad will take a restart.
After resetting your iPad with the guidance mentioned above, you'd better create a new Apple ID and password in time. After resetting iPad, you will get all the data swept from iPad, and you can restore the files from your iPad, iTunes backup or iCloud backup. However, you can't backup iPad to iTunes/iCloud without Apple ID before you reset your iPad . In this case, you need the third-party iOS data recovery software to help you recover lost data from iPad after factory reset without Apple ID.
http://www.leawo.org/tutorial/how-to-reset-iphone-without-apple-id.html
Re set ipad mini
Generally speaking, you need the Apple ID to reset your iPad. iPad needs you to enter the Apple ID to switch off your account and the Find My iPhone service will be turn off. If you are using iTunes to reset your iPad, you need to enter the Apple ID when your iPad reboots.
But if you have no Apple ID or passcode, you will have to reset your iPad without Apple ID. To reset iPad without Apple ID, you need first put iPad into DFU mode and connect it to your iTunes. Your iTunes will help you to reset your iPad without entering Apple ID easily. Resetting your iPad with this method will result in wiping all the data in your iPad. The following steps will show you how to do that.
After resetting your iPad with the guidance mentioned above, you'd better create a new Apple ID and password in time. After resetting iPad, you will get all the data swept from iPad, and you can restore the files from your iPad, iTunes backup or iCloud backup. However, you can't backup iPad to iTunes/iCloud without Apple ID before you reset your iPad. In this case, you need the third-party iOS data recovery software to help you recover lost data from iPad after factory reset without Apple ID.
How to creite an apple I'd on my ipad
you must have a credit card in order to create one.
How to create a new Apple ID on your iPhone or iPad
  1. Open the Settings app.
  2. Tap iCloud.
  3. Tap Create a new Apple ID.
  4. Enter a birth date.
  5. Tap Next.
  6. Enter your first and last name.
  7. Tap Next.
  8. Select your current email address or get a new iCloud email address.
Forgot iPad apple I'd and password
Go to https://appleid.apple.com/ and reset your id. You should have create security questions to answer. You had to use an email to create your id.
Apple ID
please be more specific with your question do you want to know how to create an apple ID or are you trying to reset the password etc. Please reply i will try to assist as quickly as possible
TO CREATE APPLE ID AND PASSWORD
Several ways to create an Apple ID. The first device you want to use, gives you the opportunity to use your computer and iTunes, or while setting up the device wireless, you can do it on the device.
You need to choose a Apple ID name and you need an mail address that will be connected toy your ID.
You can start setting up an ID with this link:
Apple My Apple ID
Create new apple id and password
Click the link to create an Apple ID.
You only need one ID for all your devices on Apple.
You can use apps you bought on 5 devices with the same ID.
Apple My Apple ID
1helpful
Apple id reset
I'm assuming you have already used iForgot etc to reset your password first or that you no longer have that email..
Go to settings, scroll down to itunes /App store.
Click on your apple ID. and you will get some options such as IForgot to send a new password etc. If you truly cannot get your password, then click Signout. Then you will be able to create a new one when you try to register, you may need to create a new email account if your apple id was linked to your old one. Your old apps that will not update, you can delete them by holding your finger on them till they wiggle and click the X. then redownload with your new ID. Hope this helps.
Top Apple Tablets & eReaders Experts
nexrad_chris
NOEL
NOEL
John
John
Are you an Apple Tablet and eReader Expert? Answer questions, earn points and help others
