Error code e01
This is a paper jam code. Try cleaning the feed rollers with soap and water and a damp cloth and see if your situation improves. sounds like the machine is misfeeding but your description was a little vague.
If it does improve you will need new rollers.
Also try flipping the paper over to see if improves.
Lastly does the paper size displayed on the screen match what is actually loaded? if not... correct as nessesary
SOURCE: Error E01-22 - Check Printer on my DP-2500
"E1-22" 5th & 6th mirror assy. sensor problemMirrors are out of position, was someone cleaning the mirrors or touched for it for a reason??? if not the sensors are bad
e01 for jp 1255 is a problem to cater master .check the cater motor or homeposition micro swich .
