I lost the setup CD for my Belkin F9L1001v1 wireless wyfy adapter. hoy can I install it
Hi
The following link takes you to a Belkin webpage where you download the driver which appears to be the same file for many OSs.
http://www.belkin.com/us/support-article?articleNum=4715
You may have to go to a library where you can use another machine or some other alternative means of web access to do this but it should work if you run the executable after downloading.
Cheers
SOURCE: how to set up network on belkin G+ wireless usb adapter
do you have a Wireless Router + Broadband modem? This is like a base station to which your remote wireless node communicates (to get connected to your home network and internet. something like this http://catalog.belkin.com/IWCatProductPage.process?Product_Id=187337 for an ADSL connection. If you are on cable, you can either get a Router similar to the one above (but for cable) http://www.linksys.com/servlet/Satellite?c=L_Product_C2&childpagename=US%2FLayout&cid=1138056788757&pagename=Linksys%2FCommon%2FVisitorWrapper&lid=8875739789B01 or if your Cable modem has LAN ports you may just be able to use an "Access Point" to add Wireless capabilities. http://www.linksys.com/servlet/Satellite?c=L_Product_C2&childpagename=US%2FLayout&cid=1126536803676&pagename=Linksys%2FCommon%2FVisitorWrapper&lid=0367639789B22
SOURCE: i lost my linksys wireless adapter install CD, how istall now
http://drivers.softpedia.com/get/NETWORK-CARD/OTHER-NETWORK-CARDS/Linksys-WUSB54GC-Wireless-G-USB-Compact-USB-Network-Adapter-Driver-3010-Vista.shtml
download from here for vista
http://www.linksys.com/servlet/Satellite?c=L_Download_C2&childpagename=US%2FLayout&cid=1115417109934&packedargs=sku%3D1134691790190&pagename=Linksys%2FCommon%2FVisitorWrapper
try both link u get right 1
SOURCE: i lost my installation cd.
I will give you a easiest way for finding the drivers that you need for
your hardware.Just download the software named driver magician.Install
it and it will search for the drivers that is not installed for the
hardware you have through internet and will download it for you.
here is the link for that software
http://www.ziddu.com/download/4569239/Driver_Magician_3.42.zip.html
SOURCE: How do I install my Belkin F5D7051 wireless
To install the adapter you will definately need a disc. because the adapter will not work without the Drivers. Drivers are very important for the adapter. One more thing that if you have WIN XP or VISTA then you don't need the set up utility but still you need the drivers for the adapter.
If you do not have the disc. You can download the drivers from the manufacturer's web site and install the drivers for your adapter.
Click her for more info about networking
SOURCE: I bought AE1000 wireless N
When you insert the setup disk on your computer, you can exit from the
setup and then connect the adapter to the computer and a new window will
popup "Found New Hardware Wizzard" and in that select the option
"Install the drivers Automatically" and click on next, so it will
automatically search for the drivers and install it on your computer...
Once the drivers are installed on your computer then you can try to
connect to your wireless network. The Linksys AE1000 Wireless USB Adapter
helps you connect your computer to a wireless network for quick Internet
access. Installing the Linksys AE1000 is fairly easy. Just follow the
steps below in setting up the Linksys AE1000 on your computer or laptop. Step 1:
Setup
Minimum system requirements
- A computer with 1 GHz or faster processor.
- 512MB or more RAM.
- An available USB port.
NOTE: The Linksys AE1000 is supported for Windows 7, Vista SP1 and XP SP3 but NOT for Mac.
Insert the Setup CD into your CD-ROM drive.
Step 2:
Click Set up your Linksys Adapter. Proceed to Step 4.
If you do not see this, click Start on your computer and click Computer. Double-click on your CD-ROM drive. Continue to Step 3.
NOTE: For Windows XP, the file may be known as Setup.exe.
Step 3:
Read the License Agreement and click Next.
Step 4:
Insert the Wireless USB Adapter into a USB port on your computer or laptop.
Alternatively, you can also use the USB Extension Base
to connect the Wireless USB Adapter. Plug the Wireless USB Adapter into
the USB Extension Base and connect the Base to a USB port on your
computer or laptop.
Step 5:
If you have an Easy Setup key, select Yes, I have an Easy Setup Key and click Next. Proceed to Step 8.
Otherwise, select No, I don't have an Easy Setup Key and click Next. Proceed to Step 6.
NOTE: For more information on Easy Setup Key, click here.
Step 6:
Select your wireless network and click Next.
Step 7:
If prompted, enter the wireless password for your network. Proceed to Step 10.
Step 8:
Follow the on-screen instructions. Click Next once you have completed the on-screen instructions.
Step 9:
The installation is complete when you see the screen below. Click OK.
Step 10:
You are directed to the Cisco Connect screen. Click Close to exit.
