Starts up like normal then after a few seconds or if i step on gas pedal it dies. i restart the car and it does the same thing.
SOURCE: I have a pontiac grand prix gt 3800 non turbo is
I have a 2003 Pontiac grand prix...I've lost power, it won't go over 30mph, it doesn't shift thru the gears smoothly. The service engine soon light goes off and on, more so when I'm trying to gas it. Its seems as tho it's 'being choked'...like not getting gas or air. So far, I've flushed the ******, changed the plugs, wires, air filter, fuel filter. I suspect the problem is a clogged cat convertor. I've been told that the exhaust can be opened a little near the cat to allow air to flow in....that should confirm if the problem is the Cat or not. I'm testing that theory today.
SOURCE: 1997 Grand Prix GTP starts but wont run for more than 5 Sec
is this a supper cahrged grand prix if so check fuel pump resistor located behind right front head light or on fire wall its made of white ceramic has to wires going to it jump the two wire on the connection going to it if it runs longer then 15 min then replace resiustor.
SOURCE: 2000 grand prix starts then dies fuel pump and
have you tried disconnecting the battery wait a couple mins then reconnect?
SOURCE: 2004 Pontiac Grand Prix GT wont start unless i press gas pedal
I had a similar prob where I needed to hit the gas to start my car, turned out the throttle body was all gummed up, after fishing it out, problem went away..
