I am trying to wire up a new switch
SOURCE: craftsman 10-in. sliding compound miter saw
there should be a safety latch on the right ..down by the base or at the back you should have to press down on the saw to release it.hope that helps..
SOURCE: dewalt power saw wiring diagram for trigger switch
The Switching should go like this
(single letters denote wire color)
Y---o o---R
B---o o---B
The contacts where the black wires attach are the points on the switch that break when continuity is checked.
SOURCE: install a switch model 77 skill saw
Here's a link to an exploded parts diagram that has a basic wiring diagram included within it. That should be enough for you to get the switch installed. The model is an HD-77. If yours is different, see here for other options.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
SOURCE: I need a left-hand metric thread bolt that holds
Go to: searspartsdirect.com and enter the full model number minus the decimal point. Full drawings of all replaceable parts will be displayed as well as parts lists and prices. Hope this helps!
SOURCE: makita LS1013 compound saw wont slide,instruction
You may find, you have a lock, button, that needs to be held in, before you can drop the saw to cut.
