Question about Dewalt Saws
Dewalt jigsaw (dw321) how to change the blade
Posted by Larry Wilt on
Jyackle5
  • 8,197 Answers
UNPLUG TOOL. To remove the blade, lift the knob on the top of the jig saw approximately 1/4".
Rotate the knob counterclockwise until the clamp is open (Figure 8a). Do not force the knob once
it stops. Insert the blade as shown. Make sure the back edge of the blade fits into the support roller.
Tighten clamp by turning top knob clockwise until you hear a click. Push knob down.
For "T" shank blades, insert blade to the shoulder of the shank.
Look at manual on the link below.
http://www.dewaltservicenet.com/documents/English/Instruction%20Manual/402086-01,DW321.pdf
Good luck please rate 4 thumbs up and please leave a testimonial
Posted on Oct 31, 2010
John Hechtman
  • 6 Answers
Instructions are clear, but URL link for manual does not work.
Posted on May 15, 2016
I have a Dewalt DW321 corded jig saw. I can't get the blade to release. The blade blade holder seem frozen.
place the shaft in the fully up position and give the collet holder a tap to move it back up further
sometimes they jam from metal, dust and grit
sometimes a bit of WD-40 or like item will lubricate the movement and make it easy to pull up
Nov 18, 2017 | Dewalt Saws
I can not find my instructions for the Dewalt321 jigsaw so i therefore cannot replace a blade that fell out
Most Dewalt manuals are available here: https://servicenet.dewalt.com/Home . There are 40 Dewalt power tools with 321 in the model number. Several are jigsaws. There are two types for the DW321 (TO3PAK-2LE JIG SAW) jigsaw. Please look at the label on the jigsaw to ensure that you get the correct model and type. The direct link to the manual for the DW321 Type 1 is currently https://servicenet.dewalt.com/Products/GetDocument?docName=402086-01,DW321.pdf&productId=2841&productType=3001&documentId=24909&translatedFileName=http://documents.dewalt.com/documents/English/Instruction%20Manual/402086-01,DW321.pdf .
To change the regular blade on the DW321 type 1, unplug the power tool. To remove the blade, pull the knob on the top of the jigsaw up about 1/4". Rotate the knob counterclockwise until the clamp opens. Do not force the knob after it stops. Insert the blade making sure that the back edge of the blade fits into the support roller. Rotate the knob clockwise until it clicks and then push it down.
I hope this helps.
May 24, 2017 | Blade Saws
How to change a dewalt DW317 jigsaw Reciprocating Shaft
You will need to remove the blade holder then the 4 screws that hold the front cover on. You can go to DeWalt's service site using the link below and view or print a parts diagram which will help.
DEWALT ServiceNet
May 24, 2014 | Dewalt DW303 Heavy Duty 65 Amp...
How do you change the blade in a DeWalt Jig Saw Model DW321
  1. Lift the black handle/knob approximately ¼”.
  2. Turn the handle/knob counterclockwise 5-7 full turns until blade chuck is completely open, keep the black knob pulled up as you turn it.
  3. Insert “T” shank or universal jigsaw blades into the chuck making certain that the back edge of the blade fits into the support roller. Please note that when using “T” shank blades, insert the blade to the shoulder of the shank.
  4. With the knob/handle still in the up position, turn the handle/knob clockwise until the knob starts to ratchet.
  5. Push the handle/knob down. The blade is completely installed at this point.
Jun 11, 2010 | Measuring Tools & Sensors
Change blade
depending on how new the saw is there are only 2 ways to change out the blade. the older saws have a allen head screw that you must loosen or remove to take te blade off. this screw is located on the shaft at the top of the blade. shed some light on it and look for a slot above the guide.the screw will be either on the right side or the left side. Newer models will have a quick release on one side or the other,it will look like a little lever,you just flip it out with your thumb the old blade drops out then you install the new blade flip it back and your back in business.
Jan 18, 2009 | Saws
Saws Logo
27,978 people viewed this question
Top Dewalt Saws Experts
efs_perpends
efs_perpends
Parson's Repair...
Parson's Repair...
JOHN LAPIER
Are you a Dewalt Saw Expert? Answer questions, earn points and help others
