Serial # 409TA00655 Goldstar
SOURCE: Goldstar MV1501BQ no heat
Hi LMGreen! Sorry for the late response a bit busy at work.. Coming back to the problem..
Solder joints on power control board are cracked and/or
burned. Inspect solder connections on power control board for
deterioration. This usually occurs where the harness connector is mounted
to the circuit board. Reinforce and re-solder as necessary. Also check all
other solder joints.
SOURCE: GoldStar MH-1357M microwave
Generally, the most common causes of a failure to heat are:
- bad door switches or door switch mounts
- loose connection at the magnetron
- problem or loose connection on the control unit circuit board
- bad magnetron or other high voltage part (such as a shorted diode)
If it's within the magnetron portion of the warranty (usually 5-9
years) but out of the original full warranty (usually 1 year), then
your manufacturer will cover the part cost, but not the cost to visit
you or the labor charge to do the work.
If you or someone you know decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and disassembly information at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
For Goldstar / LG / L.G. help, call 1-800-243-0000 (M-F, 7am-8pm CT, Sat 8-5 CT) and choose the appropriate prompt from the menu or visit http://www.lgservice.com.
We're happy to help and we appreciate your thoughtful rating of our answer.
SOURCE: microwave doesnt heat food
Microwave not heating problems are the result of one or more of the following problems -
1) Bad fuse
2) Bad diode
3) Bad capacitor
4) Bad transformer
5) Bad magnetron.
You would need to have special equipment to test the 2nd, 3rd, and 5th items.
Reply back of any other questions/help you may need.
SOURCE: microwave not cooking
I would say yes, this can be fixed. It's most likely a relay with burned contacts.
SOURCE: my microwave has stopped working. The first light
The megatron tube is out of this machine which is what causes it to heat. Replace machine.
