SOURCE: Engine RPM too high when transmission shifts. Bangs into gear.
check your fluid level when the car is warmed up
SOURCE: slight miss in engine, hard shift from 1st to 2nd long 2nd gear
Check both O2 sensor(s) and catalytic coverter.. P0420 means catalyst below threshold. Also check the sensor at the transmission and solenoid.
SOURCE: 1988 Chevy truck
no try looking at the governer on the back should be a cover about 4 in arond remove and look to see if the plastic teeth are broken or worn.
SOURCE: 2004 Impala - 115,000 miles - has intermittent hard shifts
The dealer should know this! The EPC solenoid (controls pressure) hangs up with wear and causes the harsh shifts.
The
shifter needs to be inspected. The shifter assembly is got misaligned, it has
to be open and realign.
There
are many other possibilities. But if it was working right up till now and
suddenly this occurred then its shifter
assembly alignment issue.
Also
i suggest you to refer these gear shift issues, which are mostly noticed. These
are direct links with appropriate solutions to
the specific problems of gear ****.
GEAR SHIFT ISSUES
http://howtobyme.blogspot.com/2011/11/chrysler-pt-cruiser-only-goes-in-first.html
Car is stuck in park and the shift will not move?
http://howtobyme.blogspot.com/2011/08/car-is-stuck-in-park-and-shift-will-not.html
http://howtobyme.blogspot.com/2011/11/car-will-not-come-out-of-park.html
http://howtobyme.blogspot.com/2011/11/automatic-transmission-will-not-go-into.html
http://schematicsdiagram.blogspot.com/2011/12/car-wont-downshift-sometimes.html
http://schematicsdiagram.blogspot.com/2011/12/buick-park-avenuetransmission-will.html
http://schematicsdiagram.blogspot.com/2011/12/car-transmission-will-no-go-into-park.html
http://schematicsdiagram.blogspot.com/2011/12/shift-indicator-directly-goes-to-2nd.html
http://schematicsdiagram.blogspot.com/2012/01/third-gear-missing-and-engine-losing.html
http://technoanswers.blogspot.com/2012/01/chevrolet-silverado-has-whining-sound.html
http://technoanswers.blogspot.com/2012/01/hard-to-shift-gears-on-manual.html
http://technoanswers.blogspot.com/2012/01/car-hard-shift-at-slow-speeds.html
http://technoanswers.blogspot.com/2012/01/automatic-transmission-shift-lever-hard.html
http://schematicsdiagram.blogspot.in/2012/02/2000-nissan-maxima-shifts-hard.html
http://schematicsdiagram.blogspot.in/2012/03/vehicle-noticed-sluggish-delayed-shifts.html
http://schematicsdiagram.blogspot.in/2012/06/2007-hyundai-santa-fe-will-not-shift.html
These details will help.
Thanks.
http://repairhelpcenter.blogspot.in/2012/02/car-will-not-move-when-in-gear.html
Mercedes-Benz transmission sticks in first gear?
http://technoanswers.blogspot.com/2012/01/mercedes-benz-transmission-sticks-in.html
Mercedes Benz not engaging in first gear?
http://technoanswers.blogspot.com/2012/01/mercedes-benz-not-engaging-in-first.html
Chrysler PT Cruiser only goes in First gear?
2007 Ford Expedition: How to shift car in neutral with Dead Battery
http://www.howtorepairguide.com/2012/11/2007-ford-expedition-how-to-shift-car.html
2002 Nissan sentra will not go out of park mode?
http://technoanswers.blogspot.in/2012/02/2002-nissan-sentra-will-not-go-out-of.html
Nissan Sentra stuck in park?
http://technoanswers.blogspot.in/2012/02/nissan-sentra-stuck-in-park.html
Car will not come out of Park?
Automatic transmission will not go into high
gear?
Car won't downshift sometimes?
Buick Park Avenue: Transmission will Not
shift into drive?
No
First gear Starts In Second Gear
http://www.howtobyme.blogspot.com/2012/07/no-first-gear-starts-in-second-gear.html
Ford Taurus won't shift from park?
http://schematicsdiagram.blogspot.com/2011/12/ford-taurus-wont-shift-from-park.html
2006 Ford F150: Will Not Shift out Of Park?
http://technoanswers.blogspot.in/2012/06/2006-ford-f150-will-not-shift-out-of.html
Car Transmission will not go into Park mode?
1998 Chrysler Voyager: Transmission Problem?
http://howtobyme.blogspot.in/2012/06/1998-chrysler-voyager-transmission.html
Shift indicator directly goes to 2nd when key
is turned ON?
Third gear missing and engine losing power?
Chevrolet silverado has whining sound in gear?
2002 Chevrolet Avalanche Z71: Gear shift
Issue?
http://whoisbyme.blogspot.in/2012/06/2002-chevrolet-avalanche-z71-gear-shift.html
Hard to shift gears on Manual transmission?
Car hard shift at slow speeds?
Transmission-Hard To Down Shift
http://technoanswers.blogspot.in/2012/07/transmission-hard-to-down-shift.html
Automatic transmission shift lever hard to move on cold
mornings?
2000 Nissan maxima shifts hard?
Vehicle noticed sluggish delayed shifts while
driving?
2007 Hyundai Santa Fe: Will not Shift out of
Park Mode?
These will help.
Thanks.
gear?
shift into drive?
No
is turned ON?
Issue?
mornings?
driving?
Park Mode?
Thanks.
Transmission not engaging in first
gear?
Vehicle only goes
in First gear?
Engine will not go out of park mode?
Car stuck in park?
Car will not come
out of Park?
Automatic
transmission will not go into high gear?
Car wont downshift
sometimes?
Transmission
will shift into drive?
Auto wont shift
from park?
Car Transmission
Shift indicator
directly goes to 2nd when key is turned ON?
Third gear missing
Vehicle has whining sound in gear?
transmission?
hard to move on cold mornings?
Gear shifts hard?
delayed shifts while driving?
This will help.
Thanks.
gear?
Vehicle only goes
in First gear?
Car stuck in park?
Car will not come
out of Park?
Automatic
Car wont downshift
sometimes?
Transmission
Auto wont shift
from park?
Car Transmission
Shift indicator
Third gear missing
transmission?
Gear shifts hard?
This will help.
Thanks.
