Magenta drive motor, has the magenta developer been replaced? has a PM been done on the machine did the technician use a vacuum cleaner to remove the old developer from the magenta developer unit if so he or she could have destroyed the sensor at he bottom of the developing unit NEVER use the Vacuum cleaner to remove old developer the Static electricity fro the vacuum cleaner will destroy the sensor. Check electrical connections for the magenta in unit (One connection) reseat the Magenta developing unit ensure that both guides holing all four developing units are properly installed and that all eight springs behind the guide are correctly installed. Mite want a tech to check the magenta developer motor in 47 Mode. also check signal for the Magenta ATDC Also run the required tests after any one developer is replaced May have to redo the Magenta developer again.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
SOURCE: what does code 2454 mean on the konica minolta
Developing motor for the Black, working in conjunction with Toner Control Sensor.
SOURCE: Error code C-3505 Konica Minolta Bizub C6500
This is a fuser code, which needs reset by your service provider in service modes, let me
SOURCE: konica minolta Bizhub C6500 error code 2424
Hi, I have a C6500 Bizhub pro, but, recently displays an C2404 error. I need to print an urgent job and y can't!
Please helpme!
SOURCE: konica minolta bizhub pro c6500 error c2452
i have checked all those parts and tested them with a multimeter and there seems to be no problem is there any other way i can overcome this problem
