Computers & Internet Logo
A
Anonymous Posted on Aug 17, 2014
How ccan I recover my scratch pad for free
Stopped working both pointer and clicker
cliffoa
Level 2:
Cheetah:
An expert who has answered 20 or more questions within one hour.
  • Expert 105 Answers
  • Posted on May 06, 2015
cliffoa
Expert
Level 2:
Cheetah:
Answers
105
Questions
0
Helped
15131
Points
208
Look at the top left. If there is a small dot, tap it once,
1 Related Answer
xalint1
xalint1
  • 152 Answers
  • Posted on Jun 12, 2011
SOURCE: Hi, my left clicker on
More then likely the button has worn out.The first thing I would try to check to see if its the button or not ,just plug a mouse in to the laptop and see if that works with left click if it does it just may need a new button put in.If your handy you may even be able to do it yourself.If you have any other questions just let me know.
The mouse move round with the touch pad but fail to click on to items again
click start control panel mouse you should see 4 tabs buttons pointers pointer options and hardware under hardware you have options to troubleshoot also you can select properties under driver you will have the options update driver rollback driver or uninstall in xp
in windows 7 click start control panel harware and sound mouse you will see the same tabs and options as with xp
hope this helps
Hi, my left clicker on my Sony Vaio stopped working. The right clicker works as well as the scroll pad but clicking on the scroll pad doesn't work as well. I have tried rebooting, installing the mouse...
Hello, the left clicker on my laptop mousepad has been working perfectly fine, but all of a sudden it has stopped working. The mousepad, right clicker and keyboard still all work perfectly fine. I would...
THe same thing happend to me just now grrr......
I'm really not a technology expert or anything but, when I looked inside of the the "button" I saw a small scratch on the green and gold plate. Did you perhaps notice anything like this? I'll probably have to replace it or something........
But seriously, I hope this problem is solved soon.......
I have a Dell studio laptop. Recently, within the
1. In order to fix this, you go to control panel > mouse
the last tab is called "Device Settings" click it and make sure you have "static tray icon in taskbar" selected.
(You can always remove this later.) Apply the changes and click the red coloured icon in your task bar. An option will be available called "Tap to click." Clicking it will enable you to tap with your mouse pad instead of the keys! Hope this helps you out, I know it helped my friend.
2.
In the Control Panel open Accessibility Options Icon and click Mouse Tab and than Setting.
To move the mouse pointer by using MouseKeys
If you have not already done so, turn on MouseKeys.
To turn on MouseKeys, open Accessibility Options, click the Mouse tab, and then select the Use MouseKeys check box. Use the buttons on the numeric keypad to move the mouse pointer. If MouseKeys doesn't function, press NUM LOCK, and then try MouseKeys again.
To move the pointer horizontally or vertically, press the arrow keys on your numeric keypad.
To move the pointer diagonally, press HOME, END, PAGE UP, or PAGE DOWN on your numeric keypad.
Notes To open Accessibility Options, click Start, click Control Panel, and then double-click Accessibility Options.
To specify whether NUM LOCK must be on or off for MouseKeys to function, on the Mouse tab, click Settings, and then for Use MouseKeys when NumLock is, click On or Off.
To change the pointer speed and acceleration when using MouseKeys, on the Mouse tab, click Settings, and then move the sliders to adjust the pointer speed and acceleration.
To temporarily increase or decrease the pointer speed, on the Mouse tab, click Settings, and then select the Hold down Ctrl to speed up and Shift to slow down check box.
Can't move the dialog box with the mouse using the touch pad can't move an open window or grab the end of the window to resize the window
there are two ways to do that using the touch pad. first is by tapping it twice while the mouse pointer is pointed at the ends or at the dialog box and then dragging it to anywhere you want. second way is to use the left clicker of your touch pad by pressing and holding it while the pointer is pointed at the dialog box and then use the touch pad to drag it to anywhere you want.... i hope this helps...
My notebook pointer won't work at all; cannot access computer to log on,etc.
I'm replacing the pointer with awired or wireless mouse as suggested by a computer repair person as it would be cheaper than replacing both the pointer and right clicker .
My right click menu pop's up when ever i try to click on my laptop anywhere, i have a DELL inspiron 1520.
is your pointer set to be opposite... go into control panel and mouse options, and see if you accidentally switched your mouse clicker buttons.... try clicking with the right click, does it still open your 'right-click' menu? does it work normal on an external mouse?
maybe its just a setting issue,... if not then prolly need a new mouse pad...
My alarm 'clicker' stopped working - now I have a
Replace clicker batteries leave them out and hit reset internal dot inside clicker !
Top Toshiba Computers & Internet Experts
ExpressFiX
ExpressFiX
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
