2004 Chevrolet Venture Passanger Logo
A
Anonymous Posted on Aug 03, 2014
Chevy venture air conditioning blowing hot air and smells
2004 chevy venture air conditioning blowing hot air and smells like rubber what should we do to fix problem
Stephen
Level 3:
Top Expert:
  • Chevrolet Master 21,873 Answers
  • Posted on Aug 04, 2014
 Stephen
Chevrolet Master
Level 3:
Top Expert:
Answers
21873
Questions
0
Helped
6210281
Points
67230
Is the ac compressor clutch and pulley turning ?
5 Related Answers
Anonymous
  • 828 Answers
  • Posted on May 08, 2008
SOURCE: MY AIR CONDITION IS BLOWING
http://customer.honeywell.com/honeywell/ProductInfo.aspx/
TH5220D1029#LiteratureDownload
This URL will allow you to select your model number and download the instructions.
Anonymous
  • 1865 Answers
  • Posted on May 01, 2009
SOURCE: air conditioning is blowing hot air, system fully charged compressor is woring
The problem is the venting door. There are vent doors that are used to switch between AC and heat. Some vehicles use a cable that opens and closes the vent doors, other cars use vacuum and some are electric.
Whatever the case may be, if you feel the cold on the tubes, then the AC is likely working, you have to get the vent door working
Anonymous
  • 116 Answers
  • Posted on Jul 04, 2009
SOURCE: my air conditioning blows hot air only, nothing
ok if unit is split system two piece check to see if out door unit is running fan and compressor the air coming out of the fan should be about 20 deg warmer than out door temp if not compressor not running check the capicitor to see if swelled up on top if so bad if unit has electric heat strip a heat relay may be stuck and you are running aug heat to check this pull disconect on out door unit and see if heat is out of vents if heat pump reversing valve may be bad hope this helps
steve1267
Steve Oakes
  • 234 Answers
  • Posted on Jul 05, 2009
SOURCE: window air condition (LG)
Your coils could be dirty. Also try cleaning the air filter. I am not familar with your exact model but there will be a filter behind the plastic grill. Most of them pull out from the top or bottom of the case. As for the coils get a can of A/C coil cleaner from your local hardware store and follow the directions. Most of the time these two things will get your unit working again.
Dennis Boxerman
  • 1306 Answers
  • Posted on Aug 09, 2009
SOURCE: kia spectra 2004 AC no power blows hot air
In almost every case, it is most likely low on freon. Most all systems use some type of pressure switch to prevent the unit from freezing up via a low pressure switch. It also acts as a "Loss of Charge" safety. I would think there is a leak. Most of the time it is in the condenser, evap, or compressor. Usually not real cheap to fix but you got to check it out to be sure.
Chevy venture van passenger side AC blows cold, driver's side blows warm to hot
Usually a blend door problem, either the control or the blend door itself.
2helpful
My 2001 venture van rear air is blowing hot air
often on the vans with rear air the air dor acuator goed bad and can no longer switch from hot to cold. also the swich itself will often go bad. this can be caused by sticky fingers damaging the inside of the switch. sometimes a good cleaning in warm water will fix a sticky switch
2000 Chevy Venture, rear doesn't blow cool/cold air
check the vacume / or the vacume regulator for the door exchange from hot to cold there might be a vacume problem.
1helpful
2004 chevy tahoo air conditioning wont work
Well as long as he did not unplug any fuse or repace the blown fuse in the a/c fuses spot then it just maybe just bad luck.Anyway check to make sure the belt is on the compressor,and if thats ok make sure the compressor is coming on.If it is then get it recharged and put some dye in it to help find the leak.
first thing is insure that u have the temp control turned all the way to coldest and the a/c button is pushed in (if u have one) if that doesnt work then(i hestitate to say this) have him check the fuses again. if he finds no blown fuses and this includes the ones in the box under the hood, then its off to the repair shop u go for the big rip off.
1helpful
2answers
2004 MALIBU MAXX A/C BLOWS HOT AIR
Could be several things. The fuse relay to the AC compressor could be bad. The system may need to be recharged due to lack of refrigerant the compressor will not work unless it has enough.
2000 Chevy Venture Van rear air is blowing hot air. I have replaced the controls for the rear air. Is there something else that needs checking?
can you be more descriptive? Doe's it only blow on certain fan speeds? send me a messege and let me know a lil more about it and maybe we can solve this problem.
6helpful
2answers
2004 chevy venture only gets hot air in front, rear a/c works great...is the front dampers stuck? How do I fix that?
No real solution...needs a blend door actuator, which is VERY expensive because it requires the removal of the dash board. (about 10to 12 hours labor alone)
Top Chevrolet Experts
ZJ Limited
ZJ Limited
john h
Thomas Perkins
Thomas Perkins
Are you a Chevrolet Expert? Answer questions, earn points and help others
