When I turn the air on in my 2004 ford tauris, hot air comes out. I had the systen charged. the tubing coming from the compressor are cold and I can hear it keep in. Someone suggested that it "might be the tempeture control switch . what do you think. Please healp!
The problem is the venting door. There are vent doors that are used to switch between AC and heat. Some vehicles use a cable that opens and closes the vent doors, other cars use vacuum and some are electric.
Whatever the case may be, if you feel the cold on the tubes, then the AC is likely working, you have to get the vent door working
The vent doors are located in the ducting system, beneath the dash. When you find it, you have to figure out why it isn't working
Possibly. I would first determine how the temp control works, if it be a cable or pneumatic.control, and see if it is working. You may have to disassemble the dash to do this
Where are this door located on a 2004 chevy venture van
Where are the venting doors located once I have found them what do I do. 2004 ford taurus [email protected]
do I have to remove the dash to get to the venting doors of my 2004ford taurus?
