I am locked out of the phone
There are a couple different DROID models and the directions can be a little different based on your particular model. Best thing to do is go to http://www.motorola.com/support and then find your model and search external reset.
SOURCE: motorola droid
I'm assuming you've charged the battery and you've held the power button down for several seconds. On a working phone, after a few seconds of holding down the power button (which is located on the top right of the phone), the motorola logo comes on. Else you need to take it to the verizon store (not an authorized dealer, but an actual verizon store) and they should be able to help you.
SOURCE: My computer does not recognize my Motorola droid
In order for the computer to recognize the Droid, you must "Mount" it.
To do this, first plug in the usb cord to the computer and the droid. Then touch the notification bar on the top of the droid and draw your finger down. Touch "USB connected". A popup screen appears asking you if you want to "Mount". Choose "Mount" and the Droid will appear as another drive on your computer.
Hope that helps.
SOURCE: I drop my motorola droid
It is very likely that you caused a short circuit when it got wet.
If you shorted the battery you can replace it. If you shorted the phone itself it will need to be repaired or replaced. You should contact your cellular provider for more assistance.
SOURCE: cant remember password how to do factory reset on droid motorola
You may try default phone and security code to remove restrictions.
ur defalt phones codes is 12345 or 00000 u can use it
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
