Just stopped running ,
SOURCE: Sub Zero 690
Excessive Ref Compressor Run Time.. your Ref compressor is running too long, & hot!....
SOURCE: Need to change the light bulbs
The light shield has two tabs, one on each side. They may be on the front or back of the shield, It fits either way. Pull the tabs down and slide the shield back and forth a couple of time and it should drop from the four pegs that hold it in place. You will have access to the bulbs. You can go to http://www.subzero.com/locator/locator.aspx?type=0&zip=02030 and find a parts distributor near you or take a bulb to the store and match it. Make sure you get the same wattage rating.
SOURCE: sub zero 690 the control lpanal light does not come on
If the refrigerator is working fine, you may have a bad door-switch. Open the refrigerator door, you will see two switches on top, the one on the left is for the lights; try to tweak it may just be stuck. If this does not work you have to replace it. You can double-check this by shining a flashlight behind the control panel and you can see the temp. and the other info. This means the panel is fine. You can also try to contact Sub Zero customer service, they may send you a new switch for free.
Good luck and I hope this help.
Byron12020
SOURCE: Need to change the water filter on my Sub Zero
Hello. The factory indicates your unit required an in-line water filter if your plans were to use one, or the installers added it. There was no indication of an internal filter in the fridge itself. If there was it should be easy to see or find. However this can be good news for you also as your filter (if installed) migt be easy to find and access behind or near the fridge if installed well and a good quality but common form of water filter you can easily replace may have been used, if installed. Otherwise if you have whole-house water filtering already they may not have added any further filtering.
If you can contact who installed your 690 they should be able to tell you where they installed it and what type. If not just have someone follow your water line to the fridge unit, and see what turns up as you make your way along to the place where water connects to the fridge.
http://www.subzero.com/resources/products/downloads/600installguide.pdf
SOURCE: sub zero ref 690 s model with error code ec 50
EC code is on with a flashing service light . Is this a problem that I can fix on my own?
