Unfortunately, I don't think you can reset all of the margins and tabs at once. To reset a specific margin, move to that margin and then press ALT and the 6 key simultaneously. (That's the Margin Release.) If you are resetting the left margin, press the backspace (or space) key until you reach the new margin location. Then press Alt + 7 (L Margin) to set the new margin. For the right margin, press space (or backspace) until you reach the new margin location. Now, press Alt + 8 to set the new right margin location.
You can clear all of the tabs by pressing and holding Alt + 0 (tab clear) for over half a second.
The manual for the GX-6750 is available from Brother on the product support site: http://www.brother-usa.com/support/ModelInfo.aspx?R3ModelID=GX6750 . Click on the Manuals & Documents tab. The direct link to the manual (in English) is http://www.brother-usa.com/VirData/Content/en-US%5CTypewriters%5CConsumer%5CUsersManual%5CUM_AX325_GX_6750_EN_5674.PDF / The procedure to set the margins is on page 2. The procedure to set the tabs is on page 5.
Use your space bar to move carrier to desired location, hold down Alt key button on bottom left (next to space bar) and press the number 5 numeric key on top row. That should set your right margin.
Go to the margin you want to set press but don't hold the margin release key Space or back space to desired location, Press the L. or R. margin key. You can Get an owners manual at NADIST.COM one of the current Nakajima models will be the same as your's.
the RELOC button is for when you go back and make a correction, after you make the correction you hit the RELOC button and it will automatically go back to where you left off. if you are typing along and it stops typing and won't go any further, you are at the right margin. if you want to go past this point, you have to hit the MAR REL button. then hit the space bar or keep typing. if you want to move the margin, move the carrier to where you want the margin and hit R MAR, and that will set the margin at that point. works the same way for the left margin.
You move the carrier, with the space bar or backspace key, to where you want the margin to be set.
If the carrier stops before you get to where you want to set the margin, then locate the ALT key at the bottom left on the keyboard, hold it down, then locate the key directly under the words above the keyboard that say M REL (the 3 key) and push it. Then move the carrier with the space bar or backspace key. (whichever direction you want to go)
When the carrier is where you want the margin set, hold down the ALT key and push the key under where it says L MAR (4) to set the left margin, or R MAR (5) to set the right margin.
The ALT key works with all the functions listed above the keyboard.
The CODE key works with the functions/charachters printed on the keys themselves.
On carriage return the machine locates LH margin. In your case the LH margin is set in centre.
Press the margin release key when at the margin location position.
Use the backspace key to return to the extreme left.
Space forward to were you want the new margin.
Press Margin Left set.
P {
MARGIN: 0px
UL {
MARGIN-TOP: 5px; MARGIN-BOTTOM: 5px
OL {
To get to the panel, remove the outer cabinet of
the unit, which is usually held in place with a few screws. Once the outer
cabinet is removed, follow the power cord into the unit. It will take you to
the panel holder, where the panel sits. The panelholder is located two or three
inches into the unit, and may be attached to a power board.clean or dust out ht
e face of the panel and fix back the microwave. the button will ddefinetly work
back again
Most electronic typewriters work the same way to change margin settings. You use the space bar to move to the desired location then press the right margin key. You should hear a beep. If you need to set it farther to the right of the current position, then use the space bar to move the carrier to the current position, once it stops moving then press margin release then space to the new position then press right margin key.
