Nakajima AE-710 Typewriter Logo
Posted on Mar 18, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The return is stuck on 80 on the guide. I cannot
The return is stuck on 80 on the guide. I cannot get it to return all the way to the left. Using the margin release does not work.
Dick O Reilly
Level 3:
  • Nakajima Master 3,594 Answers
  • Posted on Mar 19, 2010
Dick  O Reilly
Nakajima Master
Level 3:
Answers
3594
Questions
Helped
610234
Points
6852
Turn the T/W off and slide the carrier back and forth. If it goes to the left then you have the L. margin set at 80.
Return to the margin, press and release the margin release key, backspace to the desired location, press the L. margin key.
DickyO
When I press the controller button (any one) the blade goes to the right towards the passenger side and will not return or go up and down when I press any button.
PDF]2015 Nissan Rogue Quick Reference Guide
https://owners.nissanusa.com/.../2015-Rogue-quick-reference-guid...
NissanMar 19, 2015 - 22 Front Passenger Air Bag Status Light* ... A cellular telephone should not be used for any purpose while driving so ..... The MOD system will not operate if the liftgate is open. ... Press the ECO button 1 on the instrument panel to activate. ... When the vehicle approaches either the left or the right side of the.
[PDF]Getting to know your Q5 SQ5 - Audi USA
https://www.audiusa.com/.../dam/.../2014-Q5-quick-start-guide.pdf
Audicontrol knob with joystick, control buttons and function buttons. Pressing one of the ... While operating the menus and functions, you can return ... Tipping the knob right or left allows you to move through ... You can set any mix of up to 50 Presets from FM, AM or Sirius options. ..... Press and hold the driver's side temperature.
Meyer Plows Q & A December 2013 - Smith Brothers ...
smithbrothersservices.com/dec-2013-meyer-plows-q&a.html
To angle right the C Valve must divert all of the fluid to the driver s side PA Ram to make ... IF it was a bad coupler, it would be that the plow gets stuck and will not move, .... Message: the plow angles left to right with no problem when I go to raise .... goingbackwards through a return port and putting pressure on the coupler.
1helpful
Kenmore 80 series dryer banging
Yes you need to replace the tumbler guiding wheels .should do that soon so you don't ruin the motor and belt
May 03, 2014 • Dryers
2answers
Roller coming off guid rail while in use
This is a known problem with these machines. We ended up returning ours. Sorry!
5helpful
The lever that drops the slides gets stuck in the 'up' position when the carousel is on the projector but it works fine when there is no carousel attached. When it gets stuck you have to take the carousel...
If you are using a 140 tray with older slides, that's very logical! Over time, slides develop a "side-to-side curve". Because the Carousel 140 tray stretches the design limits of the projector to be able to accurately return the slide to the tray, the slightest bend or "dog-ear"(the fraying of the corner of the slide) will cause exactly the problem you're having. If you have a Kodak 80-Slide tray, try it. Chances are that it will work fine. If it does work fine, then you have 2 options: 1. Move all your slides into Carousel 80 Trays.
2. Have your slides re-mounted (that is, have the paper mounts replaced).
I hope this helps !!
My carriage return is stuck between 70 and 80 and I don't know how to get it back to 0 to 10. I hit return and the carriage goes back to between 70 - 80.Can you help me?
Return to the L. margin, touch and release the mar rel key, backspace to where you want the margin, press L. mar. key.
DickyO
2helpful
AE-710 Typewriter: My carriage return is stuck between 70 and 80 and ...
Return to the L margin, press don't hold the mar rel key, backspace to the desired location, press left mar. key. The R. margin works the same.
DickyO
1helpful
2answers
When loading 1st sheet of paper, the white guide bar on the left does not move to the right & the paper jams between the print head & the curved guide above. Chris of Devon England.
Hi, this is a vey common fault.If you look down where the white runner is you should be able to see two grooves cut in the base of the unit.This is the guide for the white plastic arm you are referring to. What you need to do is take a paper clip, open it out so you have a pointed end available. Push it in to these grooves and run it along to the left hand side. You'll find paper debris is stuck in these grooves which prevents the printhead from pushing the white arm across enough so it will not return. Because the arm cannot get far enough to the left hand side it sticks and you will encounter paper jammimg under the plastic guide on top of the printer. This is a very common problem on this model of printer and the Oki 520
I am using an AE-830 and have the left margin stuck in the middle of the page. How do I release and set back to the left? Thanks
Move the printer to the margin using return button. Press the margin release button, backspace to where you want the margin to be, then press the left margin set. All should be good.
Where do you add the paper on a canon bjc-8o/color bubble jet printer ?
Could not find info on a BJC-80 but did find a BJC-85. Since they are similiar you can go to:
http://gdlp01.c-wss.com/gds/0900007433/BJC-85_Setup.pdf
This is a setup guide. Go to step 5 which explains paper input and orientation.
OK, I did find a user guide for the BJC-80. here is a link:
http://gdlp01.c-wss.com/gds/0900007420/BJC80_user_manual.pdf
Go to Chapter 3 for info on "Paper Handling".
Thanks for using Fixya.
Top Nakajima Office Equipment & Supplies Experts
Mitch Vass
Mitch Vass
SmartAviator
SmartAviator
Are you a Nakajima Office Equipment and Supply Expert? Answer questions, earn points and help others
