Cd player stopped working with a message on LCD "No disc".
SOURCE: Player only plays first 3 tracks on CD and then stops
the emitting diode is not shiffting right..it might need some cleaning of its track..open it and check it out. good luck
SOURCE: cd tray mechanics
It can be repaired but in all of my years in consumer repair, I dread the CD/DVD tray alignments the worst.
There are many things involved in getting them to operate without fail. Using the mfgs documentation you can get them up and running but most of the time they failed because something is amiss to begin with. So you spend an hour getting everything setup and it will work once or twice but them fail. Only to find out that a location sensor is bad or a gear is missing a tooth....
SOURCE: KOSS CD player will not read CD says '' no disc
you need to Clean the laser lines inside the cd player I can do that for you if you want me to
SOURCE: CD player acknowledge CD, starts to play, then stops
replace belt in lazar assembly and clean lazar eye with quetip with rubbing alchol
