Technics SL-MC60 error message: "Take out"
My Technics SL-MC60 60+ cd player works fine. But, single play mode an error message "take out" displays. I pressed the stop button for 4 seconds, and then it disappears. When start again to play single cd, the same message appears every time. How this problem can be solved?
Posted by Thanga Kopalsingam on
    Top Expert:
  • Audio Player... Master
  • 76,584 Answers
Hello
If a disc has been put in the slot of the disc in play, Remove the disc, whose number is displayed, and press stop button.
Because of light or noise, the changer has detected a disc in the lot of the disc being played, even though it is empty. Check whether there is a disc in the displayed slot. With front panel closed, hold down "STOP " button for atl least four seconds or more.
Posted on Feb 03, 2012
5 Related Answers
Anonymous
  • 6 Answers
SOURCE: Technics 5 cd changer Model sl-pc11 will pick up
System will not play Mp3 or data format cds.
Audio cds only . Also Clean lenses with a cd lenses cleaner .
clean cd also straight away from center ,soft cloth
Check for scratches .
Posted on Mar 01, 2009
Anonymous
  • 3 Answers
SOURCE: Technics SL PD8 laser replacement
The answer is yes you do. The replacement laser pickup assembly has 2 motors already fixed to it so the pegs in the suspension have to be removed (2 off) and it is best to prise open the split in the receptacle to facilitate this without damage.Then 3 screws on the pcb need unscrewing and after the solder has been removed on the motors the boards will come apart.
Posted on Jan 08, 2009
Anonymous
  • 112 Answers
SOURCE: technics 5 cd changer sl-pd787
Does it show the disc length or any other details? Have you carefully cleaned the lense with a q-tip and some alcohol? Can you hear the laser moving in and out of focus? If you push the laser sled out away from the centre does it move back to the middle when youi put a disc in?
Posted on Feb 29, 2008
Anonymous
SOURCE: records alone and auto cue
this should help....follow instructions i just done mine with a 64mb nokia micro sd card from ebay (£3)
http://www.technicsforums.com/forums/index.php?topic=5.0
Posted on May 20, 2009
Anonymous
SOURCE: Looking for a drive belt
A rubber "O" Ring as a belt solved the problem.  At our local hardware store:  1 1/16 OD x 15/16 ID - 1/16" wall  $0.39!
Posted on May 21, 2009
What size o ring can I use to replace belt on my technics sl-mc6 CD changer
Save yourself $$$. Go to Ace hardware and get an O ring for 50 cents nstead of the $10 plus $3 shipping some websites want. 1 and 1/16 size. Have replaced these on a couple of technics SL MC models and works like a charm. No more error codes.
Dec 30, 2017 | Technics Audio Players & Recorders
U70 error message on cd player
U70 error message on cd player - Fixya
www.fixya.com/support/t12308553-u70_error_message_cd_player
Apr 5, 2012 - U70 error message on cd player Cd player doesn't work at all. Displays 0 track, 0:00 (min,sec). The play - Technics CD Players question.
Technics error code f 70 CD Players Questions & Answers ...
www.fixya.com > Forum > Tags > error code f 70 > CD Players
Technics cd players error code f 70 related questions and answers. ... won't play cds changer turns on ok, reads error message I have the same problem.
Apr 05, 2012 | Technics Audio Players & Recorders
Error message appears cd won't play
I don't have much to go on here. Can you post the actual message that shows up? Usually on these units, either the mechanism gets out of time or it gets jammed. The actuall message will help to determine which.
Thanks,
Dan
Mar 11, 2011 | Technics SL-MC70 60-Disc CD Changer
My Technics SL-DZ1200 will not play certain MP3 tracks. It will play some, but on others the message "track error" appears. these same disks will play just fine on the other cd player machines I have...
I believe it can only read certain bitrates. I noticed that if I run the track error files through audacity and re-save as an mp3 with 192 kbps encoding it plays fine. Give it a try - re-encoding.
Jun 08, 2009 | Technics SL-DZ1200 CD Player
How do I play full random mode
on the remote push the random button twice. the first on will be random on the disc selected. when yoiu push it twice it's full random
Nov 19, 2008 | Technics SL-MC4 61-Disc CD Changer
Random play
Hi - You can download the manual by clicking the link underlined in blue below:
SL-MC70
See page 17:
Note this feature requires the remote control!
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Informatica
Sep 05, 2008 | Technics SL-MC70 60-Disc CD Changer
