Show a torch light on the screen for a distance, and if you can see the picture, the backlight is not lighting up. Check for its settings on the remote, if you have that option. Check also the settings of brightness/contrast/sharpness/color. If you still have problems, please call in a qualified service technician.
The tv LED light on the tv front bazel frame face have the word "LAMP" light up or blinking?Yes.The tv projection lamp been inside this tv like 1 1/2 or 2 years already,tv used it everydays like 4 or 5 hrs daily?Yes.Than the tv projection lamp life are over,that why it dim picture tv now must have it tv projection lamp to be replaced.
The lamp only has a life span of about 8000 hours if you are past that then it maybe time to replace. If you average out 6 to 8 hours a day X 365 x years you will get the average hours used, not sure how old you set is but the formula works.
Hmm my dad's old t.v. just cut out on him it took awile to turn on this my be the end of ur tv so this might be a power problem but older t.v. loose there colour on the screen my uncle had a like 10-15 year old t.v the screen was like green when it was light but when u turned of the light or closed the blind's it's picture was ok so try that.
well it looks to me u need a new tv....all the details u give are pointing that ur picture tube is gone.....but call LG help and costumer line and ask them......u may get away from it to get a new tv make sure when u get a new plasma to extend ur warren tie to a max o 3 to 5 years and if this would happend u get it repaires for free.......cost for a new screen app 1000 to 1500 dollars
The procedure for correcting dark picture is EXTREMELY dangerous.. If you're not sure about what you're doing call a qualified technician or you could seriously hurt yourself or get killed!
Picture Dark, abnormal, Changing Color Temperature
Clean the Spark Gaps on each CRT PWB. Remove the Cap, clean the contacts with thin fine sand paper, blow out, reseal.
Remove the CRT Sockets, clean the pins on the CRT. Push the CRT socket on and off several times.
Make really sure before you sttart this process that the Tv has been unplugged for several hours and that you discharge the crt as you remove the anode. There is some extremely high voltage present for hours after the Tv has been off...
Or get a reputable shop to come out and do the procedure for you - - might just save picking yourself up of the opposite wall.
Bill
