CAMCORDER DISPLAYS THE EJECT SYMBOL WITH BEEPING NOISE AND THE CODE C 32:10. WHEN THE EJECT BUTTON IS PRESSED, IT LIFTS UP AND THEN WONT OPEN TO EJECT THE TAPE.
The camera's firmware has sensed a jam or too slow rotation in the cassette's take-up roller. Really difficult to overcome. The tape may already be snarled round a roller, but is certainly in the "loaded" tape path. I've had this and had to disassemble the whole tape transport mechanism - which is really difficult - after trying unsuccessfully to drive the unload motor from an external 6v power supply. Sometimes a really hard sideways bang on the camera can free up the roller enough to let it rotate a bit, satisfy the motion sensor and allow an eject.
SOURCE: The no tape and eject symbols are flashing at the same time.
Those signs means Record tab on tape is ON, eject tape and check record tab and make sure to set it on Record position.
SOURCE: Sony Handycam Vision ccd-trv308
Take the battery out and turn selection switch to camera and then turn it off. Put the battery back in and its working again.
if that doesn't work try
Try smacking the side of the camera relatively hard with the palm of your hand. Eject the tape and reinsert. You may need to do this a couple of times.
SOURCE: Tape wont play or eject.
i just read about this c:31:22 problem while looking for a solution to another problem I am having. Someone suggested removing the battery, switching the camera to the "camera" setting, and then turn it off, put the batter back in and it should work. Good luck.
SOURCE: Sony Handycam CCD-TRV37 Error code C:32:20
1. I removed the battery. 2. With the power switch On position and holding the tape ejected I inserted the battery back on & it ejected the stuck tape.
SOURCE: manual for camcorder/sony-hi8 camcorder-ccd-trv68
Download the manual from:
http://www.henrys.com/manuals/sony/CCD-TRV58(En).pdf
Please rate this solution as it helps us in helping you and others like you.
