Your coby is not charging anymore..The battery probably needs to be replaced with a new one..Please check your connection when you charge it..There should be an icon that shows your battery is charging. If it does so that means your coby is charging but your battery cant store the energy anymore.
yes. Once you plug it in it should automatically start charging. If the screen goes blank leave it for about 15 min. Unplug it and start it to see if it has charge. I hope this solution has been helpful.
if you peel off the protective film with the fake icons on it covering the screen first, then plug it in, it will show you a pic of a charging battery thats shows you how charged it is. (just like a cell phone) When it shows the battery "full"... its charged.
Charging device: Plug the device into computer. You can unplug the device any time you want without problem with device
If your device's battery has empty, you need 3 hrs to charge to full.
If you want to check battery level during devive plug into pc: (set up MTP or Auto mode) open My Computer, right click on icon of the device, select Properties, it shows you batteries level
The most common cause is a flat battery. There is a trick to charging
the battery in these small mp3 players. It wont charge if it is turned
on, and it won't charges if it's in sleep mode (zzzz). Here what to do... 1. plug the payer into your USB port. or wall charger 2. switch thje player on 3. turn it off by either holding down the play button, or selecting
"System" from the menu 4. The screen will go black and the battery will begin charging.
Your problem is probably hardware-related, and will require replacing the player, but you can try this:
Download the latest firmware upgrade from www.rcaopal.com to restore the player. The firmware upgrade file will be on the "Download Upgrades" section of the website.
