According to HP, their printers all need to be plugged directly into the wall. Tray that, and if there is still a problem you will need a tech to do some repairs.
It seems simple enough, but this is one of the most effective ways of fixing printer cartridge error. Mostly, printer cartridge error occurs when the printer head is unable to identify the cartridge properly. And the basic reason behind this is that the cartridge is improperly attached.
To reattach the cartridge check the following steps :
turn on the lid of the printer and then remove the cartridge from the printer head.
Check the cartridge to make sure that there are no scratches or other damaged parts that can contribute to a printer cartridge error report.
Take note that the cartridge should not be left open for more than 30 minutes; otherwise the ink will start to dry up and the cartridge will get clogged.
you do not clean the heads on a HP printer the heads are on the print cartridge. You can run a 'cleaning cycle' if you have noticed your prints loosing some quality.
