Related Tags:
This problem should be removed because:
Problem with Farmall Cub Tractor Radiator
changing the oil
how much oil dose the farmall cub hold
Solutions (1)
Best Solution
Hi there..my name is Keith and i restore tractors....and to answer your question..a Farmall Cub hold 3 quarts of oil..i hope this has helped
Farmall Cub 1955, runs fine for about 20- minutes
After 20 minutes acts like running out of fuel. Someone said sounds like the coil is bad. Replaced the coil and the problem is still there....
I have a Farmall H and switch it over to a12volt
I have a Farmall H and switch it over to a12volt system with a alternator with a built in regulator. I need a wiring diagram for this.
My Farmall turns over but will not start, it
My Farmall turns over but will not start, it doesn't even try to sputter. I put new plugs in and have fresh fuel any suggestions
I am installing a new radiator on my Cub (SN
I am installing a new radiator on my Cub (SN 247787) what are the torque specs for the bolts. Also should a put Permatex on the gasket?
Add Your Solution
MY 53 CUB STALLS ONCE
MY 53 CUB STALLS ONCE IT GETS HOT-ACTS LIKE IT STARVES FOR FUEL THEN DIES. gOT ANY IDEAS? THANK YOU
replacement of rear oil seal
replacement of rear oil seal on engine. IH gave me a rubber seal. is this all I need or is there a sec piec e for oil...
governor does not kick in
governor does not kick in under heavy load
Radiator on IH McCormick Farmall Cub tractor
Radiator on IH McCormick Farmall Cub tractor leaking very badly in two spots about an inch above the bottom plate,...
installing new head gasket i need torque specs on
installing new head gasket i need torque specs on head , rocker arm shaft, and valve clearence
Fix-O-Meter
210
210 people viewed this problem
- 5 people found this problem to be helpful.
- 0 people are following this problem. Be the first!
Top Farmall Riding Mower and Garden Tractor Experts
Verification:
Please enter the characters below to complete your post
Can't read it? Try a different one
