SOURCE: can't get vcr to record
Make sure you are giving the VCR a signal.
If using a RF source (cable or antenna), make sure the VCR's tuner is set up for the right type and channels.
When trying to record put the TV's input to the VCR to make sure it is getting what you want.
SOURCE: Toshiba Model: SD-V295 DVD/VCR Combo Setup for TV recording
The proper hookup is antenna or cable into the VCR RF/antenna input, then VCR RF/antenna output to the TV RF input. The hookup you describe means no signal is getting to the VCR.
With some TVs, there can be Video and audio output jacks which can be hooked to the video and audio jacks of the VCR. However this would likely mean you could only record the channel being watched, and, the TV would have to be on.
SOURCE: I am a bit confused on the directions to hook up
look on www.youtube.com for how to hook up converter box
however i get the same problem as you
SOURCE: problem recording of hd tv with cable box from
Here are a few items to check and how you need to set your recording.
1. Your HD box should have a coax out (or to TV) connection on the back of the box.
2. Connect a coax cable from the back of the HD box to the "RF IN (FROM ANT.)" in the back of the VCR.
3. When you set your VCR to record you need to set it to copy channel 3 and tune the HD box to the channel you want to record.
This should fix your problem...
Good Luck...
SOURCE: can get analog stations recorded but not hi defination
Hi, unless the VCR/dvd recorder is hi def then you won't be able to.
Hdmi connection is hi-def, I think you can have a hi-def signal through composite, but it's your recorder thats the problem, it cannot read the number of line a hi-def signal has.
I have just found this.
http://www.brighthub.com/electronics/home-theater/articles/48499.aspx
I hope this helps.
Regards - Anthony
