Sharp AR-164 Copier Logo
A
Anonymous Posted on Jun 23, 2014
Why wireless connection to printer is not working?
Skelton Business Equipment
Level 2:
Guru:
  • Sharp Expert 106 Answers
  • Posted on Aug 06, 2014
Sharp Expert
Level 2:
Guru:
Answers
106
Questions
0
Helped
64286
Points
221
The AR164 is not a wireless printer. you'd have to use a wireless bridge or an access point and connect it to your copier. That's IF it has the network print controller on it. Those don't come with one.
Skelton Business Equipment Houston Copiers
3answers
How do I connect my laptop (wireless) to my HP printer envy 5660 (wireless)?
Connect your 123.hp.com/envy5660 printer after the printer hardware setup before you print or scan from a computer through a wireless network. Install the HP printer software from a wireless network from a computer with Windows 7 or later.
STEP 1 : BEFORE INSTALLATION
  • If you want to connect the printer 123 HP Envy 5660 Setup to your wireless network, make sure you know the network name and password.
  • Connect your Windows computer to the wireless network and make sure the HP printer is compatible with the wireless
  • Obtain the network name (SSID) and network passphrase (WEP key or WPA). A broadband internet access is must be used. Make sure you have the USB cable provided along with the printer package.
  • Turn on your printer, router, and computer and make sure the computer is connected to the same wireless network you want the printer to connect to.
  • If you have connected any USB cable to the printer, disconnect it before you proceed with the software installation.
  • Follow the instructions to remove the USB installation if it was previously setup on your computer before you continue:
  • Search for the HP folder in the list of installed software programs, click the HP printer folder, and then click 123.hp.com/envy5660
  • Once the HP Printer Assistant software opens, click Utilities -> 123.hp.com/setup 5660 & Software Selection.
  • Continue to follow the prompts and click Convert a USB connected printer to wireless or Connect a new printer.
  • To complete the software installation, follow the on-screen instructions.
  • You can also run HP Print and Scan Doctor, an automated tool to connect the printer to your wireless network.
STEP 2 : CONNECT TO THE WIRELESS NETWORK
Connect your 123.hp.com/envy5660 printer to the wireless network using the built-in Wireless Setup Wizard to identify network name and entering the network password.
  • If the printer is not turned on, press the Power button to turn it on.
  • On printer's control panel, touch the Wireless icon to preview the Wireless Summary screen.
  • On the Wireless Summary screen, touch the Settings icon and then touch Wireless Settings.
  • Under the Wireless Settings menu from 123.hp.com/setup 5660, select Wireless Setup Wizard and follow the on-screen instructions to complete the setup.
STEP 3: DOWNLOAD AND INSTALL HP PRINTER SOFTWARE
Download the supportive 123.hp.com/envy5660 printer software from our website once the printer is connected to your wireless network.
  • Turn on your HP printer and eject any USB cable if connected to the printer.
  • Go to our website and navigate to the download page where you have to download the printer software manually.
  • Select your printer model when prompted and then, follow the on-screen instructions to reach the download page.
  • Next, to the full feature, click Download or click Basic Drivers.
How to solve HP Printer issues 5X Faster Answer is inside
Set up wireless
Wireless Method:
  • Make sure your printer has wireless network adapters or a wireless router.
  • Power on the printer and wireless router.
  • Configure the printer to connect the wireless router.
--Enable the DHCP option on the printer. Obtain the IP address automatically.
--Configure the DHCP server of wireless router. Again, assign the IP address automatically.
  • Verify connectivity. Try doing some test prints. If it doesn't work, check the IP addresses.
Network Method:
  • Assign the printer to a wireless network. Go to "Start" and click on "Devices and Printers."
  • Click on "Add a printer".
  • Click on "Add a network, wireless or Bluetooth printer."
  • Select the wireless printer from the list. Click "Next."
  • Allow Windows to successfully connect the printer. Again, click "Next."
  • Click "Finish" to complete the process. If you have multiple printers on your network, set this one as the default. Verify the connection by clicking "Print a test page."
If you need any technical help on printer then you can reach at http://www.vtechsquad.com/
1helpful
I cannot connect wireless to my HP 3520 printer
Please check your wireless connection? are you sure you are typing the correct username and password for your wireless on your printer. if it is still not working fine then you need to call hp tech support at toll free number- 1-800-585-2494 or visit: HP Customer service . hope this will help you better.
2answers
Can we use MF6550 for wireless network?
If you use a wireless USB print server like this . Keep in mind that you may not get all functions such as scanning to work but it will allow for printing for sure. If the scanning works consider it a bonus.
OfficeJet Pro L7780 controls non-responsive
There is conflict between the Printer and Router you are using. The Router is freezing the printer connectivity to the network due to the Wireless radio ON option in the printer
There is a firmware update for your printer, Let your printer be connected thru USB and from this link, download and install the update for your printer and later try setting it up wireless, it should work.
http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=mp-62339-2&lc=en&dlc=en&cc=us&os=2093&product=2512010&sw_lang=
If this step fails, the other step is, to Enter the printer IP Address manually in the printer Network menu from SEtup Option and later run the wireless setup wizard to connect it to the network.
Connect a wireless laptop to an existing wired network printer
Hi!
Its designed for wireless, but you need an adapter to make it wireless, the adapter
"Dell Wireless Printer Adapter 3310 USB2"
I dont know if that adapter came whit your printer when you bought it, but thats what you need to make it wireless
Good luck
Nic
2helpful
Cant connect printer to wireless laptop.
have you setup the wireless connection in between the printer and the laptop...
your laptop is working wirelessly with the internet but for making the printer to use it wirelessly the printer should be also a wireless printer.
and if the printer is a wireless printer then you have to setup the connection in between the printer & laptop to work wirelessly.
Can't make the wireless feature work
C4480 is not a wireless printer per-say.
what they mean is that if have a wirelss router you can connected it to the router and printer from any wirelss connection.
you do need a wireless source. this printer don't have one.
1helpful
2answers
HP Photosmart C7280 wireless connection
My experience is different. My DSL router died in the night and I had to install the old one. I just changed the wireless settings on my C7280, and now all three connections work. If no wire (ethernet or USB) is connected, the wireless connection works. If the Ethernet cable is connected, it works via Ethernet, and if the USB cable is connected, it works via USB. It seems to default in that order.
Top Sharp Office Equipment & Supplies Experts
k24674
ZJ Limited
ZJ Limited
Norman Weimar
Norman Weimar
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
