Grohe Integrated 1/2'' Shower Thermostatic Rough-In Valve With Stops - 3412 Logo
A
Anonymous Posted on Jun 16, 2014
Why is the water cold to shower from combination boiler?
1 Related Answer
Anonymous
  • 83 Answers
  • Posted on Jul 08, 2009
SOURCE: my thermostatic concealed shower valve only gives
If the hot and cold are fitted the wrong way round then the thermostat on the shower unit cannot operate properly!
Most thermostatic mixer showers have a 'bi-metallic' thermostat, if you supply the hot to the cold and vice versa IT WILL NOT WORK.
It is like wearing the left shoe on the right foot and the right on the left! It doesn't work.
Re-install the hot and cold to the correct supply, and this will sort it.
I hope this helps.
I HAVE A BOSCH GWH10-2 G HOT WATER BOILER. THERE IS GOOD WATER PRESSURE ON THE COLD TAP BUT WHEN IT COMES OUT THE SHOWER HEAD ITS VERY LOW PRESSURE. WHAT CAN I DO
first id check shower head most has a screen in them and do get clogged from time to time since the water flows good from faucets
I have a Potterton Combi Puma 80e When I use the shower the pressure seems to drop and shower goes cold! except when the central heating is on shower works fine
Does the red status led in the centre of the control board come on when hot water is drawn? You need to remove ONLY the front decorative cover to see the control board, two fixing screws at the base of it. If not the boiler won't fire when the CH is off.
The trigger for this is a pressure switch, replacement of which is beyond DIY scope.
FYV
Code 13 help... Everytime I go to use the shower (a mixing system of hot and cold) Code 13-- Code 12 the system shuts down. If I just use hot or cold I am fine-- Any one?
if cold supply to boiler and shower are off the same feed this could be your problem as the boiler governs flow of hot water best of luck
1helpful
Vaillant ecoMAX 828/2boiler goes on & off when running hot water!
water must be set at 3lts a min ,check diaphragm valve move when hot tap is on, check microswitch ,best of luck
4helpful
My thermostatic concealed shower valve only gives either boiling hot water or cold water, there is no inbetween temperature? the cold is fed from mains and the hot from a combi boiler. the plumber has said...
I hope this helps.
4helpful
2answers
I have exactly the same problem
you need to change the cartridge, it is a temp control and is going bad so it keeps you from burning yourself it is like a mixing valve and is givng more cold water, that way you don;t get burned,,
3helpful
2answers
Top Grohe Water Heaters Experts
Paul Carew
vince
ADMIN Andrew
ADMIN Andrew
Are you a Grohe Water Heater Expert? Answer questions, earn points and help others
