Installing a new Grohe shower faucet, not sure how to adjust the water tempature setting before I install the trim?
Before you install the temperature control knob, adjust the valve body (47111) with a wrench to set the temperature to "100 degree or close to it". Now, place the limit ring to tdc (top dead center) and control knob with the red 100-degree align to it. Your problem may have been the valve's temperature setting is out range when you installing the temperature control knob.
It is easy. remove central screw put control back on turn the knob to desired setting and tighten the screw
The temperature adjustment dial cna be rotated when you loosen it, take a thermometer , turn the water on and set the temperature dial to the right temp, then tighten the screw holding it and you're all set
