Question about Grohe Grohmix Thermostat Valve & Trim - 34436
My grohe shower thermostat is set too hot. How can I adjust the valve to allow more cold water? I don't have a manual and don't know the model number. It is a high end unit - flat face plate on the wall with large round temperature controller in the middle. Face plate has two screws, which I removed and I was able to look behind the plate but wasn't able to remove because I'm unable to remove the large round controller in the middle. Thanks for your help.
Posted by rodlewis556 on
  • 1 more comment
  • rodlewis556 Feb 19, 2011
    Thanks. I went to the Grohe site a few minutes ago. Our shower is approx 5 years old. The current model that appears to be the closest match 19 229. The only difference is that our face plate is flat and rectangular. The valve head is very similar. Can I just pull the head off? I am afraid to pull too hard and have not been able to get it off. Is there a screw or button that I need to push to get the head off?
  • rodlewis556 Feb 22, 2011
    Thanks for your help. The usual temperature readjustment for the thermostat numbers was not enough. I think took the green adjuster out of the unit, but was unable to get it back on with the washer attached. Without the washer it fit back on - without it did not. I tried to force it back on with the washer, and it broke since it is plastic. Will have to figure out from here whether I can find the plastic or will need to get an entire kit. Thanks again.
    That's great. Thanks again!
Jyackle5
  • 8,197 Answers
This should help you with setting the hot water on your valve.
Maximum hot water limit setting
The adjustable hot water limit stop (F) is factory set in a neutral
position (0), see fig. [5].
On applications requiring to limit the valve opening from full hot
position, the factory set adjustable hot water limit stop must be
reset as described below.
1. Remove the factory set adjustable hot water limit stop (F),
see fig. [6].
2. Slide the adapter (G) onto the valve stem (B) by placing the
stop post (G1) on top of "Arrow" ? (H), see fig. [5] and foldout
page III, fig. [7].
3. Turn the adapter (G) counterclockwise until the outlet water
reaches the desired temperature and read the corresponding
number (1 to 10, see fig. [5]) against the stop post (G1).
4. Close the valve by turning the adapter (G) clockwise and
remove the adapter (G).
5. Align the white mark (F1) on the limit stop (F) against the
number (1 to 10, see fig. [5]) you have selected on the dial
and slide the limit stop (F), see fig. [8].
6. Proceed to item 6 in chapter "Installation" to install the
lever (N).
Or you can go to the link below page 4
http://www.groheamerica.com/lib/1/tpi/1118884.pdf
Posted on Feb 19, 2011
  • 1 more comment
  • Jyackle5
    Jyackle5 Feb 19, 2011
    I know this might not be your valve but they all adjust the same. If you woul like on the link below has all there valves if you let me know what one you have I can help you more. Also If you have a question please ask.
    http://www.groheamerica.com/en/bathroom-...#
  • Jyackle5
    The handel should unscrew. You will need to unscrew the cap on the front of the handle and then you will see a screw that holdes the handle on. On the link below showes you how to put it together.
    For Maintenance, see figs. [5], [6], [7] and fold-out page II.
    I. Thermostat cartridge
    1.Turn thermostat handle (47 427) or lever thermostat
    handle (47 432) to the 100 °F safety check, see foldout
    page II.
    2.Remove thermostat handle cap (47 428) and
    decorative ring complete (47 429) or lever
    complete (47 433).
    3.Take out fixing ring (M), see fig. [5].
    4.Pull off thermostat handle (N).
    5.Pull sleeve (F) from the mixer shank by pressing
    down the tongue (R), see fig. [6].
    6. Extract clamp (E).
    7.Pull stop ring (D) until resistance is encountered
    (approximately 3/8" [10mm]), see fig. [7].
    8. Unscrew stop ring (D) complete with regulator
    nut (D1).
    9.Remove escutcheon (47 543).
    10.Close service stop (47 467).
    11.Unscrew thermostat cartridge (47 582) with 24mm
    open-ended spanner.
    Reassembly should be carried out in reverse order.
    Here is the manual on link below.
    http://www.groheamerica.com/lib/1/tpi/79...
    page II.
    complete (47 433).
    nut (D1).
    open-ended spanner.
    http://www.groheamerica.com/lib/1/tpi/792652.pdf
  • Jyackle5
    Jyackle5 Feb 22, 2011
    Contact Grohe at the link below. They will send you parts.
    http://www.groheamerica.com/en/contact-g...
    Or you can call them at +1 800 44 GROHE 1 800 44 GROHE
Could my grohe thermostatic shower be letting cold water into my system? Some other taps run cool but the shower is running OK temperature
If you have single handle facute one bad cartridge in the system may be acting like a mixing valve and allowing cold water to mix with hot not allowing water to get hot enough .
Mar 10, 2015 | Grohe Water Heaters
Grohe valve Grohtherm Thermostatic Rough 34-126 I turn the mixer to full hot but the temperature remains tepid. All the other faucets in the
The thermostatic stop is set too low. Havent set a grohe before but most other thermostatic shower valves work similar. pull off the handle(however a grohe handle comes off . . ) there should be a notched ring or stop which keeps the handle from going all the way hot. pull out the ring and turn it a few teeth hotter put back and reinstall handle try water temp and adjust again if necessary.
Jan 23, 2010 | Grohe Grohtherm Thermostatic Rough-In...
The temperature in my shower is very luke warm only at the shower
Do you mean the other faucets in the house are hot and only the shower is warm? If so there is an anti-scald adjustment on the faucet that needs to be turned up a few notches. Havent adjusted a Grohe faucet but most faucets you rmove the handle and behind the handle is a nothced adjustment ring that prevents the faucet from getting too hot. This ring, or stop, is pulled out and twisted clockwise(or counter clockwise to set higher or lower max temp, then pushed back. maybe you can look up grohe to see which way ring or stop adjusts for hotter water.
Jan 23, 2010 | Grohe Integrated 1/2'' Shower Thermostatic...
Hot water not as hot from rain head as other outlets
i'm quite sure you shower valve has an adjustment on handle that allows more hot water into the mix,........it will tell you how in the paper work that came with the valve,....good luck, cracklin joe
Jan 06, 2010 | Grohe Grohtherm Thermostatic Rough-In...
Water not coming out hot enough
adjust the thermostat setting on your hot water heater. They are located in different configurations. Consult your water heater manual
Dec 22, 2009 | Grohe Integrated 1/2'' Shower Thermostatic...
Grohe shower. I want to adjust the temp mixing valve. I can not get cold water. It is always a mix-never pure cold. I want cold water. How do I adjust it?
if you pull the handle off all the way back to the valve body there is a little black stopper around the cartridge body that you can adjust by pulling it out and sliding around the cartridge body this enables people to just turn the handle to one setting and jumpping in to their favorite temperature. in your case it doesn't allow you to have any cold water. so turn it one way see if you get what you want or try the other or some of them you can even just take the darn thing out and not even have to worry about it
Jul 29, 2009 | Grohe Integrated 1/2'' Shower Thermostatic...
I have exactly the same problem
you need to change the cartridge, it is a temp control and is going bad so it keeps you from burning yourself it is like a mixing valve and is givng more cold water, that way you don;t get burned,,
Jun 18, 2009 | Grohe Integrated 1/2'' Shower Thermostatic...
Grohe Thermostatic Valve
the temp, control valve is getting to hot!!! there for only let so much hot water go thru, did you take the inner parts out when soldering this in, if not you might have damaged it, and if so need to replace the cartdrige
Feb 10, 2009 | Grohe Integrated 1/2'' Shower Thermostatic...
Grohe Grohmix Thermostat Valve & Trim - 34436 Logo
17,562 people viewed this question
Top Grohe Water Heaters Experts
Paul Carew
Don Walper
Level 1 Expert
ray gallant
Are you a Grohe Water Heater Expert? Answer questions, earn points and help others
