I have used this product exactly once. Now the disc tray will not open. How can this be fixed?
DVD door is opened by a small pulley-belt system. Disconnect the power cord and remove cover on R6740 (one screw on each side and 3 in back). Remove top cover on DVD drive (4 screws on top). Manually open door; you will see a small "O" ring sized rubber belt (they stretch and lose flexibility with time, which is why the door stops working). Remove and replace belt. I found a 11/16" X 1/16 belt at Lowe's in the plumbing dept @ 2 for $.59. Its not a perfect fit, but the door works now!
I have used the R6740 Go Video recorder approximatly 50 times. The disc tray opened sporadically and now it will not open at all. Does anyone have a solution?
I have this machine for a while now. Never had any problem. Used it last on Saturday but the tray will not open on Sunday. Resetting the machine does not help!
Have had this dvd recorder for approximately 3 years. Rarely use it, but now the disc tray will not open. Can't seem to find a solution for this problem in the manual. Anyone have a clue as to what I should do?
