Question about RCA DRC8295 DVD Recorder/VCR Combo
Dvd tray will not open or play
At first it would show reading disc for a long time but would not play. Now the disc tray will not open at all.
  • 484 Answers
The reason your player keeps reading a disc and do not play is because the the disc tray is not sitting the disc properly on the lens.
The disc tray is faulty, the mechanism that controls the opening and closing of the tray is damaged and needs repair.
To fix this, you have to get the appropriate screwdriver, open the cover of the player.
You will see a mechanism by the opening of the tray that controls the disc tray.
Get a replacement mechanism and change it. Mostly the rubber slacks and does not control the tray properly.
Changing the mechanism will solve the problem.
Take care
Posted on Jun 15, 2010
2 Suggested Answers
6ya staff
SOURCE:
Eric Andersen
  • 16 Answers
SOURCE: Liteon DVD recorder LVW-5045 has disc inside and won't open tray
Use your knuckles to knock on top of cabinet just above disc tray door while at the same time pressing open button,99% of the time disc tray will open.The problem you have is caused by a worn out belt drive or the tray is out of alignment.The disc tray belts only cost $2,when tray is open you can see the minature belt that controls door to the right.Use twizzers to remove and replace.Belt size 1.9
Posted on Aug 09, 2009
Dvd player will not eject or play dvd. It just keeps spinning and says "reading." I've tried unplugging for 2 minutes, pushing close/open and stop at the same time(hold for at least 3 seconds)....
Plug the power cord back into the electrical outlet and turn the player ON. Attempt to open the disc tray. Depending on the model number of your DVD player, simultaneously press the POWER + STOP + EJECT buttons. If the disc tray still does not open, simultaneously press the DISC1 + STOP + EJECT buttons.6 Jan 2013
Solved: DVD is LOCKED will not eject. please help. Manual ... - the ...
https://community.sony.com/t5/Home-Theater.../DVD-is...will-not-eject.../td.../55919.
or try this link. Dvd player will not eject or play dvd Google Search
Oct 18, 2017 | RCA DRC8295 DVD Recorder/VCR Combo
Ps2 wont play DVDs
Your PS2 laser is wearing out. When the laser starts to go, first games will skip... then eventually the PS2 will stop reading DVDs altogether. If you keep using it to read CDs, it will eventually stop reading those too and the laser will die altogether. Here's a website that will help you identify your PS2 model, show you how to replace the laser, and they sell parts and do repairs too
http://store.richspsxparts.com/slps2direerl.html
Oct 05, 2009 | Sony PlayStation 2 (PS2) Console
My 360 will not read my disc even tho they are clean
The optical drive on the xbox wears over time. Call 1-800-4MYXBOX and get a repair scheduled.
Aug 03, 2009 | Microsoft Xbox 360 Console
Aug 02, 2009 | Lite On LVW-5005X DVD Recorder
Jvc dvd player not playing
Even you don"t have a remote you can play it manually and DVD player play it automatically.Just try this open the tray put the DVD disc on the tray and close it then turn it off for 30 seconds then turns it on then it play automatically if not then there's something wrong to the player.
Hope it may help you:
Regards:
VOTIT
Mar 23, 2009 | Audio Players & Recorders
Unable to play cd/dvd on my laptop
LINK
This is a dvd player codec.
LINK to sony support for tool necessary for dvd to read
May 19, 2008 | Siemens Computers & Internet
DVD stopped playing all DVDs
Reset you player by doing the following:
With the player on, hooked properly to your television, and on the correct station:
Open the tray
Close the tray (with no DVD inserted)
Hold the stop button down for a full 5 seconds
The CyberHome screen should appear. You should be able to play your dvd's now.
Feb 20, 2008 | Cyberhome CH-DVD 300 DVD Player
LG LHY-518
I had the same problem. Also, the disc tray had issues opening if there was no disc in there. The problem was two fold... I think.
1) It was kinda dusty inside the machine and needed a good air can dusting. Get around the tray but be careful not to turn the can upside down and freeze components. I also ran a lens cleaner disc several times.
2) The tray top (only visible with the system open) was starting to warp... likely because the build up of dust was creating too much heat, also causes issues in reading discs... I created a make shift cushion that I taped to the top of the plastic tray that was depressed when the top of the machine was placed back on. This required several tests as if too much pressure was applied, the tray wouldn't open at all and I got read issues in the middle of playing a disc (possibly an alignment issue of the lens caused from the pressure). I finally got a good system where I occasionally have push the top with my finger to open the tray only if it was empty so my padding (made from gauze and gauze tape) was barely getting pressure. Again, this took about 30 minutes of trial and error to get it right. The heat and the displacement due to the warped cover could have caused read issues.
I don't know if either or both of these were the cause of the problem but I can safely say that I have no issues now and yes, prior to this, I slowly went from 100% reading discs to almost 0%.
Sorry for the winded response but this saved me from buying a new system and may save you. Good Luck!
Dec 30, 2007 | LG LHY-518 System
Not closing
Hello, with mechanical problems with sophisticated systems of gears etc, the only way thate one can fix it is if you send me a digital picture yourself. To access the inside of the DVD player, you will have to get a handyman to open the DVD player up with a screwdriver, by undoing some screws which hold the cover to the player itself. Then, with the player's circuit boards (The Green/brown Boards with weird components on it) showing, take around 5-6 photo's of the loading tray and the playing tray.(Where the disc is when watching a movie)In the time being, open the layer's cover as instructed before, and look at the inside of the tray for any broken plastic, debris or anything stopping the tray from opening. Good luck!
Oct 05, 2007 | Sony DVP-NS305 DVD Player
RCA DRC8295 DVD Recorder/VCR Combo Logo
1,514 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
