Possibly dirty or dead video recording head. If cleaning wont help then most likely repair is not cost effective. Save your video tape collection to digital format before unit expires.
U play another movie like a Hollywood movie DVD disc play on it have no squealing noises wright?Yes,than the blank DVD discs batch u have is bad.Tries buy another batch DVD blank discs,tries recording again should solved this problems.
I understand that you're not getting sound on the recorded videos when playing it in the Camera itself. Unfortunately, due to the bad design, the Camera does not have a built in speaker to generate sound when playing videos. It is required to connect the Camera to a TV or transfer the recorded videos to Computer to hear the audio on the videos. This is same for all DSC S Series Cameras.
Thanks for understanding. Please let me know if you require any clarifications.
Check your display(on screen) do you see a word "NARRATION"? if so switch that off(can be found in the menu). Or it could be your internal speaker busted. To confirm connect it to your TV, sound must be heard on tv. Otherwise, have it check by the expert. Good luck
DSC-S930 does record sound and you can hear video clip sound by playback of Media Player in Computer. This camera does not have inbuilt speaker for playback sound but it have inbuilt mic to record sound, transfer recorded movie clip in computer and play it with media player to get sound and picture. Hope this info will help you.
Video camera has built in microphone which is on at all time until you plug in different type of mic then camera is switched to new mic. Audio problem may be on audio head or circuit problem. You can test the system by playing pre-recorded tape to see if it play with the sound and go from there. If it play but does not record sound, you have audio recording problem. If it does not play, I would clean the video head and audio head area good. -James For further assistance, request help at www.camerarepairjapan.com
Since it is playing the tape, the play head is ok. Now recording is done by recording heads so you may have a clogged heads or damaged recording heads. Try to clean the heads with head cleaning tape to see if it would help. 1. remove the tape and leave the door open. 2. using a canned air, blow out any dusts in the tape area. 3. run head cleaning tape for about 10 seconds and no more. 4. try the recording.. If this does not resolve, you may have a damaged or heavy clogged video heads. Take it to nearest video technician for a diagnostic. -James
Hi, i had the same problem 4 ages. every time i tried to playback my videos there was no sound, i did so many videos trying to get the sound going and then i played them on my computer and ther was sound, :) lol i felt like such an idiot when i found out there's no speaker on the camera it self.
If there is an external microphone jack on the camera, it would help if you tried recording with an external microphone. Also, the mini DV's will mute the sound if the tape guides are slightly out of adjustment. You can tell if they have moved by trying a known good sound tape in the machine. If that plays with no sound also, the tape guides have moved out of alignment.
