20 Most Recent
JVC GR-D270 Mini DV Digital Camcorder Questions & Answers
Camera skips in playback
I have The JVC GR- D270 its about 10yrs old and it skips every second while playing an the Safe guard at times will interfere the playing . Now what?
Record button not workig
hi,
there is several reasons for not work the record function, first of all make sure that the cassette is good and the safety tab is in record position, then check the playback of the cam with a recorded cassette, if this tests passed, check the rec button for loose or it is sticky, if so please use contact cleaner in the switch.
still the problem persists there should be problem in the circuit board. open total camera put it in record mode then test the wave shapes in the record paths up to the video head
JVC gr-d270 driver
Hi guys,
I have a JVC gr-d270. the CD came along with it is useless.
my computer cannot detect the video cam hrough USB. I have to transfer
my videos to my computer. Can anybody help me with the driver atleast.
Im using windowsXP sp 2.
Thanks
What kind of memory card do i buy for my jvc gr-d270u
The GR-D270U uses SD cards. They should be available at just about any department, electronics, or office-supply store.Make sure you get an SD card, not an SDHC card. While SDHC cards will fit into the slot, they are electronically incompatible and will not work.
No image on lcd screen or viewfinder
This is usually caused by a defective CCD image sensor. This will require disassembling the camera and removing the lens assembly to repair and can be done fairly inexpensively. However, it's not really a user serviceable problem and should be repaired qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
I have a jvc grd375u
http://xpdrivers.com/jvc/_2_135637.cfm?gclid=COGa4tjm0aoCFQ6AgwodzX7Qzw
Follow the link above!
