Frigidaire Affinity 5.8 Cu. Ft. Gas Dryer Logo
Anonymous Posted on Jun 01, 2014
My frigidaire affinity front load gas dryer has a banging noise when it runs
  • Frigidaire
    Frigidaire Jun 02, 2014
    Good Afternoon Michael, I understand your Frigidaire Affinity dryer is making a banging noise when it runs. I will be more than happy to assist you. If I could please ask for the model number of your washer, this way I am able to better assist. Looking forward to hearing from you. -WP-
J.D. Browning
Level 3:
  • Frigidaire Master 2,760 Answers
  • Posted on Apr 21, 2015
J.D. Browning
Frigidaire Master
Level 3:
Answers
2760
Questions
0
Helped
1015223
Points
6696
You;ll have to examine it closely with a good flashlight to see if u can detect any gaps in drum to front cover (front and back), seam should be even all the way around if not it's gonna be out of balance and hit at points in its rotation , ive seen every thing from baby socks to necklaces get in there and mess it up
5 Related Answers
dragonsthatk
Albert Getty
  • 547 Answers
  • Posted on Feb 18, 2009
SOURCE: FRIGIDAIRE AFFINITY ELECTRIC DRYER NOT STOPPED HEATING
eleiment
TheMobilian
Dan Webster
  • 8221 Answers
  • Posted on Jun 09, 2009
SOURCE: how to replace fuse dryer frigidaire affinity
If it is like any other frigidaire dryer it is mounted on the upper right hand corner of the rear bulkhead.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
TheMobilian
Dan Webster
  • 8221 Answers
SOURCE: my Frigidaire dryer makes a banging noise
What you have here is a drum bearing issue. Read my award winning essay on this subject right ova HERE
Anonymous
  • 193 Answers
  • Posted on Nov 10, 2009
SOURCE: my frigidaire affinity front load dryer shows the
AD is a indication of board problems.I would unplug the unit for 20 minutes to see if unit will reset
rohdd
jay kaye
  • 305 Answers
  • Posted on Mar 07, 2011
SOURCE: My Frigidaire Affinity AEQ7000EGO dryer
Could be one of 4 problems:
  1. Worn or loose drum drive belt (Looks like a large fan belt) (New belt cost $12)
  2. The rear bearing(s) is bad and needs replacing (part cost $18)
  3. The front bearing guide(Sleeve) is worn (Part cost 2@$18.00
  4. Possible that the fan is loose from the motor and hitting housing.
All of the above are easy do at home repairs if you re handy. You should be able to get a good idea of what is wrong just by turning the dryer drum by hand. If the problem is the front bearing or guides, you will hear a grinding noise in the front at the top of the door.
Below is a link to diagrams and parts for your dryer. - J
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5156927
Thanks for using FixYa - a 4 THUMBS rating and POSITIVEComment is really appreciated for the FREE answering of your question.
Capt. Spock said: "An ancestor of mine maintained, that if you eliminate the impossible, whatever remains, however improbable, must be the truth."
Frigidaire Affinity Door Open
Help in the link which also refers to the thermal limiter. It is a gas appliance and should be only serviced by a certified and registered gas technician.
https://www.google.com/search?q=Frigidaire+Affinity+Door+Open
Cant open the front door seems like its locked
My frigidaire affinity dryer displays LOC - Fixya
www.fixya.com/support/t4561247-frigidaire_affinity_dryer_displays_loc
my frigidaire affinity dryer displays LOC and will not allow me to press any buttons what does that mean? please - Frigidaire Affinity 5.8 Cu. Ft. Gas Dryer question. ... Hi i have a front load frigidare dryer and it displays the cycle time when you press start but it blinks back & fourth to loc & whatever cycle its ... Open Questions:.
2helpful
Hi, I have a frigidare affinity front load washing machine and when it is running a cycle it sounds like the drum is banging around in the machine. It's a new noise, did something come loose? What
Hello gen0313 - From what you are describing it sounds like the unit could possibly have a broken shock/bearing or damaged tub. A certified technician will need to accurately diagnosis the bearing and pulling system behind the drum for repairs.
1helpful
2answers
Hi, our washing machine started making very loud banging and whining noise in the final spin cycle and the machine was shaking. We have taken off the back. The springs look ok. any suggestions?
Loud banging is usually an unbalanced load. whining noise is some times debris trapped in drain pump causing it to squeal like a fan belt on a car. Strings, threads and hoses tend to get wrapped under agitator and cause noise, too.
IDry Frigidaire Affinity Gas Dryer Error "AD" shuts off in 5 min
Great. This is the same error my electric dryer is showing now...
Load noise not spinning
hi if its a loud humin then its your berings. if its a banging then its your spider hope this helps
4helpful
2answers
My Frigidaire dryer makes a banging noise
Top Frigidaire Dryers Experts
ZJ Limited
ZJ Limited
Paul Bade
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
