Jandy Aqualink RS-PS8 Logo
A
Anonymous Posted on May 30, 2014
Scheduled filter times start ok but filter will noit turn off at correct time. it stays on continuously
David Spradling
Level 3:
Renaissance:
An user who is expert in 3 categories / brands.
  • Jandy Master 1,448 Answers
  • Posted on Oct 18, 2014
David Spradling
Jandy Master
Level 3:
Renaissance:
Answers
1448
Questions
Helped
519179
Points
1901
Make sure programming has a shut off time
Does seagate external hard drive back up the whole system each time it backs up or only new data?
Step 1:
It will depend on which back up program you have or selected usually it will back up the entire system.
Scheduled backups are an integral part of any effective disaster recovery plan. The Windows Backup Utility is offered in a free download on Microsoft's website and, while it is not the most feature-rich tool on the market, the Windows Backup Utility will back up files to hard disk, CD-Recordable (CD-R) or tape at the times and dates specified for the scheduled job. Editing scheduled jobs can be easily done. Click the "Start" button in the lower left corner of the window. Select "All Programs." Choose "Accessories" and "System Tools." Select "Backup." Click the hyperlink "Advanced Mode" in the "Backup or Restore Wizard" window. Choose the "Scheduled Jobs" tab. Click on the icon in the calendar for the job you want to edit. Select the "Properties" button from the "Scheduled data" tab. Choose the "Schedule" tab. Select the task schedule from the drop-down box beneath "Schedule Task." Set the start time by clicking the up and down arrows in the box under "Start Time." Choose the "Settings" tab. Select the desired options using the check boxes under "Scheduled Task Completed," "Idle Time" and "Power Management." Click the "OK" button. Click the "OK" button in the "Scheduled Job Options" window. Type the user name used to run the job in the space beside "Run as" in the "Set Account Information" window. Type the password and confirm the password. Click the "OK" button. Click the "X" in the upper right corner of the "Back up utility" window.
http://www.microsoft.com/resources/documentation/windows/xp/all/proddocs/en-us/ntbackup_schedule_backup.mspx?mfr=true
New intermatic timer installed. I can turn on manually and it will turn off at designated time but will not prgress to turn on automatically.
If display shows, and timer turns lights on-off with manual override, then timer is wired correctly, and battery is good.
If timer will not turn ON at scheduled time, but turns OFF correctly, then best suspect is the programming.
Open following link for ST01C programming steps.
http://waterheatertimer.org/ST01C-program.html
Program1 is ON
Program2 is OFF
Program3 is ON
Program4 is OFF, etc
Review your schedule: Press Mode button until PGM starts flashing, and then press ON-OFF button until 01 starts flashing.
If Program1 cannot be set for some reason, then set your ON schedule on Program3 and ignore Program1. The timer does not mind if you have OFF set on Program2 and ON set on Program3 or Program5 or Program7 etc.
If you have multiple programs, for example different ON-OFF times for each day, then check for scheduling conflicts that will cause timer not to function as expected.
If timer is defective, contact seller about 1-year warranty.
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
3answers
I am trying to find a maintenance schedule for my 2003 Passat...it has almost 130K miles on it, but everywhere I look the maintenance schedules stop at 100K. Any help is greatly appreciated!!
The 100K schedule repeats continually.
What needs to be done at 50K and 100K, then needs to be repeated at 150K for example.
The schedule only needs to go out to the longest delayed item.
1helpful
Water pump changed. car would noit start afterward.
was the pump timing chain driven!! f so thats probably your problem, timing is off. if all was ok before the job then it is the chain. get a good book, and follow directions carefully if need be. on the nissan it is reccomended to change the timing belt every 60,000 miles.
2answers
How do you unblock your computer with a D-Link DIR-628 router? My brother blocks me and I'm trying to play some team fortress 2. My connection just dies cause he blocked the router at the worst times. Is...
You can do a port forwarding first, remember, to configure router you have to log in as an administrator.
Type in this in your browser's address bar.
http://192.168.0.1
Log in.
These are the ports
Steamclient1: 27000 - 27020
Steamclient2: 27020 - 27050
SteamServ: 27015
Do like this(at your own risk-port forwarding may be vulnerable)
This will allow you to open a single port or a range of ports.
Port Forwarding
Enter a name for the rule or select an application from the drop-down menu. Select an application and click << to populate the fields.
Enter the IP address of the computer on your local network that you want to allow the incoming service to. If your computer is receiving an IP address automatically from the router (DHCP), you computer will be listed in the “Computer Name” drop-down menu. Select your computer and click <<.
Enter the TCP and/or UDP port or ports that you want to open. You can enter a single port or a range of ports. Seperate ports with a common.
Example: 24,1009,3000-4000
Select Allow All (most common) or a created Inbound filter. You may create your own inbound filters in the Advanced > Inbound Filter page.
The schedule of time when the Virtual Server Rule will be enabled. The schedule may be set to Always, which will allow the particular service to always be enabled. You can create your own times in the Tools > Schedules section.
You can also add application rules
Name: Enter a name for the rule. You may select a pre-defined application from the drop-down menu and click <<.
This is the port used to trigger the application. It can be either a single port or a range of ports.
Select the protocol of the trigger port (TCP, UDP, or Both).
This is the port number on the Internet side that will be used to access the application. You may define a single port or a range of ports. You can use a comma to add multiple ports or port ranges.
Select the protocol of the firewall port (TCP, UDP, or Both).
The schedule of time when the Application Rule will be enabled. The schedule may be set to Always, which will allow the particular service to always be enabled. You can create your own times in the Tools > Schedules section.
Your brother may be filtering your mac address(network card address)
Check from Advanced->MAC address filtering
Turn it off.
You can set a policy also to prevent this.
Here's how
Go to Advanced-> Add policy of your router configuration page.
Do the following
Click the Add Policy button to start the Access Control Wizard.
Click Next to continue with the wizard.
Enter a name for the policy and then click Next to continue.
Select a schedule (I.E. Always) from the drop-down menu and then click Next to continue.
Enter the following information and then click Next to continue.
• Address Type - Select IP address, MAC address, or Other Machines.
• IP Address - Enter the IP address of the computer you want to apply the rule to.
(To find the MAC address
(click Start, then Run, then type cmd in the text box.)
Type in ipconfig/all in the Command Prompt Windows.
The 12-digit Physical Address is the same as MAC address
Select the filtering method and then click Next to continue.
Access Control Wizard (continued)
Enter the rule:
Enable - Check to enable the rule.
Name - Enter a name for your rule.
Dest IP Start - Enter the starting IP address.
Dest IP End - Enter the ending IP address.
Protocol - Select the protocol.
Dest Port Start - Enter the starting port number.
Dest Port End - Enter the ending port number.
To enable web logging, click Enable.
Click Save to save the access control rule.
Go to tools-> syslog to create a new user. you can create an admin account here.
You can download the manual of the router from here.
If this is helpful to you, please rate this :)
Thanks :) Wish You Luck
3helpful
Rinnai convector 404
You have a dirty pilot assembly and maybe even a bad ECO switch (safety switch). I would suggest replacing the ECO and removing the pilot assembly and clean it out.
I don't know how to access my Western Digital Backup. I have no icon to click.
hi
If you have a WD Media Center, Dual-option Combo, or Dual-option USB external hard drive, you can use the Retrospect Express software that comes with the drive to create a backup schedule that will backup your data onto the drive.
To setup an automatic duplicate schedule in Retrospect Express 6.5 on a PC, please follow the instructions below.
  1. Start Retrospect Express by pressing the Automatic Backup button on the front of your Media Center external hard drive after you have installed the Retrospect software and powered on and connected the drive.
  2. You will be presented with the Western Digital Automatic Backup Wizard. Click Next to continue.
  3. Highlight the drive(s) that contains the data you wish to backup and click Next. To select multiple drives or folders, hold down the Ctrl key and make your selections.
  4. You will have a choice to backup your documents only or all files, make your selection and click Next.
  5. Highlight the drive you wish to copy your data to and click Next.
  6. You will have the option to run the data duplication daily or once a week. Make your selection and click Next.
    • If you choose a daily duplication, you will have to select the time that you'd like the duplication to start each day, then click Next.
    • If you choose a weekly duplication, you will have to select the day and time that you'd like the duplication to start, then click Next.
    • If you wish to run the duplication one time when you are finished setting up the schedule, check the Start the backup now box and click Finish. Otherwise, just click Finish.
    • You will see the Automatic backup button glow a solid blue. When the blue light is on it indicates that the automatic duplication schedule is enabled and your duplication is set to run at the scheduled time.
For the duplication to run successfully, you must have both the computer and drive powered on and connected correctly at the scheduled time.
1helpful
Dishwasher drains continuously
I dismantled and checked various parts of the dishwasher and everything seemed to be working. I noticed with a phase tester that the pressostat never got any voltage. This led me to check the microswitch on the door which turned out to be broken (never making any connection). This is the microswitch that turns off the dishwasher when someone opens the door.
So an unusual problem - two faults at the same time i.e. clogged and overflowing drain and broken door switch!
I ordered and fitted a new door switch and now the machine is working fine again.
Mar 27, 2008 • Dishwashers
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
ZJ Limited
ZJ Limited
john h
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
