SOURCE: My printer c5280 keeps saying please reinsert or lower photo tray
This model appears to have several trays for print media see the manual. Check the default print settings by right-clicking on the printer icon in the Printers and Faxes folder and see that the default is set to what you print most. Also verify all trays are inserted properly and that you have plain paper in the paper tray.
SOURCE: HP photosmart 8250 wont print from photo tray.
Follow these steps in the order presented to resolve the issue.
Step one: Reset the product
Step two: Check the condition of the paper and reload it
Step three: Choose the photo tray in the print driver settings
Step four: Service the printer
If you have completed all the steps listed above and are still experiencing a problem, service the product.
Photo tray problem
' Lift the output
tray up and verify that the photo tray ' is pushed in until it stops, then lower
output all the ' way down. Press OK
button on the printer to 'continue printing
HP Photosmart C7280 All-in-One Printer
1. Turn off printer.
2. Pull out paper
tray and photo tray
3. Remove output
duplexer (on back of printer)
4. Open input sheet
feeder (on top of printer)
5. Open cartridge
access door. (Basically lift up control panel and scanner section of the
printer)
6. Turn on printer
(Power button on now raised control panel)
7. Printer may
display message "Performing printer alignment - Do not interrupt"
8. Wait for a few
minutes until printer stops making all setup noises.
9. Close cartridge
access door, close input sheet feeder, replace output duplexer, insert paper
trays
10. Do a test print. All should be fine.
