SOURCE: I have a casio triple
Casio solar watch has no battery it is powered by solar,but there is a storage capacitor like a battery.It will last for 5years that capacitor.Try to hold all the buttons and press hold simultaneuosly for 7 seconds this for reset the watch..
Hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE.
SOURCE: Casio pro-trek PRG-60T Buttons no longer activate anything.
Is the battery indicator on L (Low). If so only timekeeping will work. Check out the manual which tells you that.
Try sticking the watch in a window to charge it till the battery indicator gets to H (may take up to 10 days for a very run down battery). If that doesn't work it send it to Casio for a battery change. Cost of change just over 20GBP sterling.
SOURCE: reset casio pro trek prg 80l after discharge of
You can find details here:
http://world.casio.com/wat/download/en/manual/
Rate me, plz.
SOURCE: casio PRO TREK error 'OP EN'
The problems is very simple: On the back cover (inside) is a little Cu metal Part. This part is glued to back cover using a poor glue (rubbered glue) and, in time, is moving from original position. You must put back this parts to original positin ( a little hole inside of back cover) and glue using a good glue. When the back cover is mounted , this part must have a ferm contact with two springs from mechanism (sensor for back cover open). If beatwin this springs isn't a electric short (using Cu metal parts) the internal mechanism of watch "see" the back cover is open and show "OPEN" on screen!
Testimonial: "Simple .... once you know ! (as most things) The "obvious" question is: How did you figure it out ? But THANKS !!"
SOURCE: Casio pro trek prg-80T model 2894 display says "open"
May need a battery replacement. My solar atomic watch battery died after 3 months. Casio said the battery was not covered by the warranty. Check this YouTube video for the battery replacement process:
http://www.youtube.com/watch?v=ogCz2vjUKVg
