The program selector just spins around in a circle, it does not click into any program.
SOURCE: Bosch nexxt 500 series dryer
I had the same trouble after moving to a new house, I first thought I had a voltage problem. It turns out that the heating coil has a high temp re-setable switch in side the back - lower right side. the sencor has 2 screws, I took it out and cleaned off the lint and now have dryed 5 loads with 0 issues. looks like a flaw in design that would allow lint to get in the heating coils!!!!! I think I'm going to look for a new dryer before I burn down the house!!
SOURCE: Bosch nexxt 500 plus dryer does not heat up. I
If you have a gas dryer.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer is electric..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
SOURCE: Bosch Nexxt 500 series dryer, E:01 and lint light
This indicates the sensor near the lint filter gets too hot. This is usually caused by bad air flow.Try running the unit without the vent hose attached. If the problem goes away the problem is in the ducting.
You may need to have it cleaned out. May be lint filter is clogged due to the use of dryer sheets or fabric softener. You can try to clean the filter with Windex.
If neither one of this suggestions resolves the issue there may be a problem with the sensor, there may be heat escaping somewhere within the dryer. This is only resolved by technician.
Good Luck and have a nice day.
Rating the solution is highly appreciated.
SOURCE: my bosch nexxt 500 series electric dryer is not
We had the same problem. Cleaned out lint filter and still no heat. We took off the back (lots of screws and had to take top off to get back off). If you are looking at back - at the bottom left there was a red reset button and it clicked when we pressed it (when we pressed it again there was no click). Worked fine after. This solution came from internet. My brother-in-law changed setting to "extra dry"- we usually just used 20/40/60 setting. I think it overheated.
SOURCE: I have a Bosch Nexxt 500 series dryer. Today I was
Hello, Welcome to FixYa. There are a couple of scenarios which may prevent the dryer from starting with Bosch, but based on your post it is most likely the emergency shut off/belt switch. It is located by the motor and in the event of too heavy a load or a broken belt it shuts the unit down & prevents any restart...until it is repaired or reset. To save time and back and forth dialog, I`ll mention what to do about it. **Unplug the dryer before attempting any repair tips suggested here please...safety first** This will require you to remove the back panel. Once you've remove the rear panel, It is located next to the belt pulley and all you need to do is push it to the right ( from the back ) Let me know if you require further assistance to do this. Keep me posted how you make out or if anything is not clear. I'm presently on my iphone, but I can post more info with pictures to guide you if necessary...but please let me know. Thanks for choosing FixYa and good luck. Regards, Macmarkus :)
