Front panel conectors
SOURCE: PC Chips M955G Motherboard Front Panel Pinout
nesesito los controladores de esta tarjeta madre PC Chips M955G Motherboard x favor diganme co obtenerlos
SOURCE: need the motherboard manual for a m810d ver 7.5 motherboard so i
there web site is here http://www.pcchips.com.tw/PCCWebSite/Downloads/ProductsDetail_Download.aspx?detailid=203&DetailName=New&DetailDesc=&CategoryID=1&MenuID=6&LanID=0
& manual here
http://www.pcchips.com.tw/PCCWebSite/Downloads/DownloadFile.aspx?catid=1&driverid=393&areaid=2&LanID=0
SOURCE: i need to conect the
You could try looking on the line to see if there are any available online manuals or if theres an available number call the manufacturer. I just went to the manufacturers website pcchips.com and found manuals to a v7.1. You might be able to use one of those manuals as a referance point.
SOURCE: CASE WIRES TO PANEL1 CONNECTIONS
The hdd red wire gooes to pin #1 the hdd white wire goes to pin #3 the power sw orange wire goes to pin #6 the power sw white wire goes to pin #8 The reset sw blue wire goes to pin #7 the reset sw white wire goes to pin #5 the power led green wire goes to pin #2 the power led white wire goes to pin #4.
Now the layout of the pins is the long row (5) pins are the odd number pins 9 being the odd one and 1 is the other end of the row. 2 through 8 start at the pin accross from 1 : : : : . I hope this helps you.
