SOURCE: Can I replace the thermometer on my Weber Genesis
Lightly tap on the pointy end of the thermometer, and it should snap out of the bracket that holds it. Snap replacement into position...
SOURCE: New Tank won't light Weber Grill
Try checking the regulator, this is the round metal piece connected to the gas line. If this is not level flat the valve inside will not let propane flow through.
SOURCE: Gas is not moving from tank to Weber silver grill
GOOD LUCK AND PLS RATE THIS POST!!!!!!
SOURCE: How to replace ignition switch
where does the ignitor switch plug into ? genesis ....came unpluged
SOURCE: have a type 6980 gas regulator not getting enough gas to the burner
Hi leonard4538
Regulators are notorious for doing just what yours is doing.
After sitting in the same position for a length of time they freeze in that position, then along comes a grain of sand, or other debris and blocks the gas flow.
Remove the regulator if possible, if not try it in place with the tank removed.
Get a plastic headed hammer and gently but firmly tap on the regulator, your trying to free up the diaghram inside.
After tapping and freeing the regulator diaphram reinstall and you will be good to go.
If this does not work, the replace the regulator as it is defective.
Some regulators are ajustable, if you have one of those then try to adjust the regulator, you will see a cap on top of the regulator, that is where the adjustment screw is located.
Please take time to rate me
Bud
