SOURCE: I have a Xerox CX-700.
check it there's some obstacles in mechanical parts or the printer is dirty with ink spread inside mechanism. it needs to be clean
SOURCE: this is an error code
THE BELT HOME POSITION TOO LONG
If this fault is declared 3 times in succession, the print mode will be disabled. In order to clear this condition, reset NVM location 741-105 to 0.
[IMG]pws://file/xerox/edoc/olym/icons/arrwup.gif[/IMG]Procedure
Check that the Transfer Belt is in the center (where the IBT Belt Edge and the IBT Belt Frame are approx. the same distance from the front and rear). Center if required (see REP 9.3).
Perform ADJ 9.13 Belt Edge Learn Cycle. .................
You must use a PWS
SOURCE: On the Xerox 700 Digital
1. Check the front door and the toner door are both closed.
2. If that doesn't do it try powering the printer on and off. Note be sure to allow the machine to completely turn off before turning back on.
Best of luck!
