We have PSC QS6000 plus scanners using USB cables (new installation). We are having difficulty programming the settings for the Interleaved 2 of 5 leabel. We need to configure it to not transmit the check digit.
The setup documents that come with the scanner do not include settings for the I 2 of 5 label.
When we try to use the programming sheets for the PS2 QS6000, the scanner decodes the barcode instead of going into programming mode.
Any ideas are greatly appreciated.
Everything you need is came from your system mechanism. The only way to control your requirements is came from your programm coding.
at the start of the string sending must be filtered and rearrange from your program mechanism.
From what system you need to used barcode scanner? Are you using POS?
Hope you like my solution please rate me Solved.
best regards,
Philip
my psc qS6000 plus was working just fine then I plugged it into a different computer and it kept trying to install, it finally installed, but now it doesn't work properly. The scanner scans the barcode and beeps, but the number doesn't show up on the computer. I've tried different computers, but it does the same thing on the other ones.
