Fedders A6X05F2D Air Conditioner Logo
A
Anonymous Posted on May 12, 2014
A6X05F2A How many BTUs?
How many btu's does the fedders model # A6X05F2A have?
The unit should have a boiler plate behind the front panel indicating btu's and other electrical parameters. Look for it. Or Google the unit
5000 btu..
Need tonnage for Carrier model# 48TCED08B2K5A S/N 2610G30670
You see that 48 at the begining, that is 48,000 btus. 12,000 btus per ton of cooling that makes that piece of equipment a 4 ton unit. hope this helps.
Fedders A6X05F2A fan has stopped working, and therefore air conditioning has stopped. Could the fan be the problem (or just the dirt and gunk I have to clean out?)?
Honestly, it could be either one. But, to save on costs, clean out "dirt and gunk" first. Be sure the unit is turned OFF and unplugged before attempting any cleaning. FYI - Hosing it out does not count as cleaning. And could do more damage than good.
Hope this helps you and thanks for choosing FixYa.
Whats the tonage of this condenser
Tons of cooling or heating are done by btus.
So 6000 btus is 1/2 a ton,12000 btus is 1 ton.And so on.
You need to get the total btu rating off the unit then figure it out.
Im just trying to find out how many btus my air conditioner is
It says it in the model number 12000 btus or one ton enough to cool 700 to maybe a thousand feet.
Trying to find ton rating for a Tempstar 9000 mod# CA903VKA2.
If this is a window or portable unit, you will not find the tonnage only the BTUS. My guess is 9,000 BTUS
3,000 less than a ton
Does my hampton bay unit blow heat
if it does, on the name plate it will have a split rating for the btus. one for cooling and one for heating. if there is only one rating i.e. 8000 btus, then it is just for cooling
2helpful
2answers
Need to know the BTUs on stovetop Burners
BTU ratings are usually the Model Number plate which is located in one of three places for Maytag:
1-Underneath burner top if top lifts up easily
2-On left lower front edge of frame with door open
3-Left edge of front oven frame with drawer open
What is tht tonage if i have a model#wpka 031jaz weatherking air conditioner
2 1/2 T the 31 in the model # is 31,ooo btus divide by 12,000 btus in a ton
1helpful
What's the BTUs for a Frigidaire window AC, model A1838?
it is in the model number a (18000 btus)38 this is a 1.5 ton.
Top Fedders Heating & Cooling Experts
Jay Finke
Jay Finke
Mike Cairns
Mike Cairns
Aron
Are you a Fedders Heating and Cooling Expert? Answer questions, earn points and help others
