I cant reprogram the scanner. It is only in channel 6
To restore normal operation, try RESETTING the scanner:
- Power the scanner OFF, then power it ON again.
- Insert a pointed object, just as the end of a paperclip, into the RESET opening on the side of the scanner, then push the small button inside the opening.
In many cases, the RESET will restore operation. If not, you'll need to perform the more drastic INITIALIZE process. NOTE: INITIALIZE will erase all information that you've programmed into the scanner and restore it to original factory settings. To INITIALIZE the scanner:
- While holding sown the TUNE/CLEAR key, press the RESET button as above. The scanner display should shut off.
- When the display turn on again, release the TUNE/CLEAR key.
Need the manual for your scanner? You can download/print it here:
http://support.radioshack.com/support_electronics/doc69/69887.pdf
For a comprehensive database of active frequencies in your area, and a lot of other useful scanning info, visit:
www.RadioReference.com
Bill B
