Coffee and Espresso Makers
Problem for Coffee and Espresso Makers
Generic problem for all Coffee and Espresso Makers
No power to the coffee maker
By tabipapa on Jun 21, 2009
after opening the machine, at the bottom where the element is, i have no power. it seems there is a resistor or diode in the way that appears to be opened. Am i on the right track? model of the machine is
Comments:
Jun 21, 2009
- thanks for the reply co7196. unfortunately it's not a fuse, wish it was. as i said, it may be a diode or a resistor. it has a temperature rating on the component, 240 celsius i think.
Jun 22, 2009
- i wonder if i can take a pic of the component and email it to you so you can hopefully tell me what it is. please let me know.
Jun 26, 2009
- sent you an email with the pics. sorry it took so long.
Pete
Jun 26, 2009
- thanks Ned, will do. gotta to go to work now but will do it very soon.
Jul 05, 2009
- Hi Ned, sorry for late reply. I pulled as much as I could but the wire did not move. I metered both end of the wire to where they go and there is continuity. I don't think it's a fuse but most likely a temperature cut off. The markings on the component are as such: DYE tco PQKM DF240S 240 °C That's the way they show on the component. I assumed DYE was the manufacturer. Quick search online with DF240S indicates the part is a Thermal fuse. The only thing I don't know is how to determine the current rating I need. I'll look on the back of the coffee maker to see if I can find out. It's either 10 or 15 amps. I'll keep you posted. Pete
Solution #1
posted on Jun 21, 2009
Not Helpful)
co7196
Rank: Wiz  Kitchen Appliances  Expert
Rating: 84%, 1151 votes
A glass tube? If so, its a fuse. yes , you are on the right track.
Comments:
Jun 21, 2009
- Ok, Very possible it's a resistor. Looks like a coil and burnt in two.. Can you remove it? If so, Any electronic store should have one I don't know your location, so it would be difficult for me to refer you to one in your area. I'm in riverside,ca.
Jun 22, 2009
- Yes, please send the pic of the part in question. Thank you, Ned co7196@yahoo.com
Jun 26, 2009
- Ok, got and revieed the pics. I just need answers and a pull. Is there a voltage rating marke on this device and is ther an ampereafe marking? Now, with one hand hold the body andusin thumb and finger put sull ungpressure and see if the wire on each end will stretch the insulatio.. If the insulation stretches it is a fuseable link. Often used for this very reason, to force the consumer to have it repaired or replaced, since most if not the majority would simply chane a standard fuse or replace a standar looking fuse with a larger one ignoeing the cause of its failure creating a hazard. The beauty of a fusible link is that yhey can be cut out of the circuit and replace with like,if you can find one, Or replaced with a more common fuse of like amp rating, which would reqire a holder for the replace fuse to be soldered in. These are also used in automotive applications and drive mechanics crazy. It is advised that it not be bypassed by direct wiring. Try to identify the volt/amp rating and check with a local electronics supply store. They should have or be able to order one for you.. If you are unable to locate one, which I recommend like replacement, let me know, I have a very good electronis store in my vicinity.and I can search and aquire one for you. They should run but a couple of dollars and can be mail for what ever postage. Let me knoe Peter. At lest we are moving along. Ned
Was this helpful?
Yes
No
Popular Solutions for Coffee and Espresso Makers
Questions and Unsolved Problems for Coffee and Espresso Makers
Answer
which style of the bodum french press' is best, the chombard, brazil, or kenya?
Answer
Where in North-Central London can I purchase a replacement gasket for a 1-2 cup vigano stovetop... (More)
Answer
via venezia broken portafilter in less than 6 months!?
Answer
Krups b50 rubber ring surrounding needle fell off how do you put it back on?We have the ring I just... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Coffee and... Experts
Top Small Appliance Repairmen
(316) 283-4211
(316) 283-8664
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
