If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
SOURCE: My monitor turned off suddenly and wont turn back
It is probably the power supply in the monitor. Call Dell and see if they will replace it. If the cost exceeds half the price of the monitor, purchase a new one. I know you can get a 20" acer from best buy for around $99.
SOURCE: have 21 inch monitor dell st2210,mi problem is
Connect the monitor to some different computer, e.g., a laptop, to verify that the monitor is working.
If not, take it back to DELL/STAPLES, and get them to check it out, or to exercise the "warranty" to get it repaired/replaced.
SOURCE: "Power Saving Mode" problem
To solve your problem please remove RAM and then insert it again. It will resolve your issue. All the best
Testimonial: "thanks i'll try it"
SOURCE: On my Dell ST2210 monitor
Not really, this looks like a pressure mark which has damaged the screen surface. Easily done by pressing the screen with a finger or pencil / pen.
I would like you to run a self test on the Monitor to make sure that the monitor is working fine.
Self test on Dell ST2210
