Pitco Frialator SG14 Deep Fryer Logo
n
nancy Zabel Posted on Apr 20, 2014
Flames cominhg out of flue - Pitco Frialator SG14 Deep Fryer
Kennynva T.
Level 1:
New Friend:
  • Contributor 20 Answers
  • Posted on Apr 20, 2014
Kennynva T.
Contributor
Level 1:
New Friend:
Answers
20
Questions
Helped
16527
Points
57
Hi I use to repair every kind of restaurant equipment under the sun..maybe I can help...Is this a new install of the fryer and it never did this before, or did this just start do this..If a new install, the first thing I would check is the gas regulator and see if it is for Nat gas or Lp gas, and find that out..cause it has to match what you have, comming into the building..usuall the gas valve has a sticker on it that says what the water columbs are like for Nat it is like 3-6, and for Lp(propane) it is like 5-12. Ive seen customers buy a used fryer, and install a LP fryer in a Natural gas build, and the valve lets too much gas to the burners, and it will shoot flames out the top..then you would have to buy and convert a gas valve, or use parts to convert it..let me know further..
5 I have a Bradford White gas water heater. Model number MI 403 23626 number 1 3 1 - 7 7. I have replace the thermocouple because the pilot light will not stay lit. It will heat up for a little while, then...
Check pilot flame is it good, is the thermocouple in the flame, is the flue causing a down draft, or to much updraft, Is the ceiling in your closet close to flue to keep a downdraft out. Last replace gas valve.
I have a Vulcan lg400 propane fryer it has only been used 4 times for catering events. yesterday we were using it and after a while it started what seemed like mild back drafting the flame was actually...
Hi there. Flames rolling back instead of shooting inside the fire tubes can be a result of clogged fire tubes or air entering the flue, also check if there are objects blocking the flue. Regards.
I have a Dometic 2913 and like many others it works fine on both AC and DC but has stopped cooling on propane. I cleaned the flue, the flue baffle, the burner and the jet and still no cooling. Any other...
Was the end of the spiral flue baffle burned up? If it was it could be disrupting the air flow which will not allow it to reach the proper temperature. Does the flame stay lit or does it go out after a while? If it is going out after a while the thermo-switch that detects high heat may be shutting it down due to the flame being too hot. Fire prevention safety...
Flames coming out of top and going into flue pipe
Did you change the orifice and regulator from Natural Gas to LP Gas? IF not, that's the problem.
Where is the flue/flame sensor located at on my Pentair master temp 400gas heater?
Hy my pulsar 150 slow running bymitake off I try start not start continue kiks after 10 to 20 munitus I again start plies my problem sove
1helpful
3answers
Pilot light keeps going out after about 10 seconds on my Gazco Riva 67 inset fire.
you do not say if it is a conventional flue or balanced flue model. If it is a conventional flue you cannot just buy a thermocouple. It is integral with the pilot assembley and must not be tampered with. This is an ODS safety device. The problem might not be with the thermocouple as there are other components on the circuit.
Heater fires up and runs for a few seconds and shuts off think the heat exchanger is filthy would that cause it.
There are several things that can cause this:
Check for blockage in the flue pipe or improper flue design resulting in inadequate venting.
One way to quickly determine a venting issue is to visually observe the flame on the burn tray. It should NOT be yellow and should burn evenly across the burner. There should NOT be any areas of the burner that appear to burned or deteriorated. Look for evidence of leaks,
You may need to dismantle the top section of the heater to visually inspect for sooting.
You may need to inspect the flame sensor mechanism (if applicable) for dirt or sooting.
If it is determined that your exchanger is sooted up, you have a blockage in the flue pipe or improperly designed flue.
I have a RM 2811 2 way dometic is operates fine in A/C mode no
Hi there. When calling for cold, flame should be large and blue. If orange, clean mixing tube, flue, chimney. If still orange, adjust "air" inlet on mixing tube to get blue flame.
Thanks
Paul
1helpful
2answers
Toyo 56
Hi ejohn,
There is no valuable, practical adjustment for the flame on a Toyo Stove. A yellow flame can be caused by several things. How old is the stove? When was the last tune-up? A dirty sooty carboned up stove will have a yellow flame. A breach in the flue pipe will cause a yellow flame. An incorrect installation of the flue and exhaust hoses/metal exhaust elbow will cause a yellow flame. In the last scenario, the intake will be hooked to the exhaust and the exhaust will be hooked to the intake ports of the flue pipe. A malfunctioning fuel pump can also cause a yellow flame. The wrong fuel can cause a yellow flame, too. Most likely, your stove is dirty and needs a tuneup. It should have a bright blue flame if it is clean, and operating correctly. You can download a manual at REE, Anchorage through a Google search. If you want a more detailed diagoses, write back and give me more detail and I can help you further. Toyotech
Top Pitco Frialator Kitchen Appliances - Others Experts
Paul Carew
ADMIN Andrew
ADMIN Andrew
Are you a Pitco Frialator Kitchen Appliances - Other Expert? Answer questions, earn points and help others
