Don't have the manual and need the torque settings for a peugeot 206 1.3L 2000 model
SOURCE: Torque setting for peugeot 206
hallo
If you have normal 1.6 liter 206:
max bolt lenght:176,5mm
20Nm and aditional 240°
1,6 liter 16valve engine
max bolt lenght:122,6mm
20Nm and aditional 260°
Marko
SOURCE: torque setting for 2005 peugeot partner front wheel bearing
hallo
2005 peugeot partner front wheel bearing torque: 320 Nm
hope it helps
Marko
SOURCE: Does anyone know the torque wrench settings for
Tightening torque for the hub nut is 200Nm and the road wheels are 85Nm
NOTE:
The rear wheel bearings are remowned on these cars for sticking to the
stub axle quite badly, and often have to be forced off using a slide
hammer on the drum, it is quite common to end up damaging the wheel
bearing, so be prepared to replace this as well in this event
