Question about AEG Refrigerators
Electrolux refrigerator displaying H1 celcius, freezer not freezing?
Model S85628S1
SOURCE: Top freezer Freezes/ Bottom not cold
defrost problem. advance defrost timer to defrost (till it shuts off) . remove freezer panel, check voltage and amps to heater,if heater is hot, replace timer, if heater is cold and no voltage, replace defrost limit switch. defrost all ice, carefully! with hair dryer, no poking with screwdriver.
Posted on Nov 05, 2008
BNewberry
  • 93 Answers
SOURCE: Frigidaire Electrolux Not freezing but fridge seems cold
You may be having a freon issue. Read some more info about this here. I type the longer version on my site. There are also factory service manuals to that may be helpful.
Appliance Outlet
Thanks,
Bill
Posted on Nov 25, 2008
sdmc73
  • 121 Answers
SOURCE: GE Profile refrigerator model PFCS1NJWA is freezing items in back
slow air flow will cause it to freez check air flow from freezer in at the top and back at the bottom
Posted on Nov 30, 2008
rpbuice
  • 161 Answers
SOURCE: Freezer compartment of refrigerator not freezing
First, I think it’s important to know that the Ref side has no cooling coils, it’s basically a box and the cold air in the freezer is blown over by a fan through a channel into the Ref side. This channel has a door which regulates how much cold air goes through. You probably have two control knobs in the Ref side, one controls the temp with numbers 1-9, 9 being the coldest. This temp control tells the compressor how long to run. The other control is for that little door and it may have letters A-E, E being the coldest. If you set it on E (coldest) then this will close that little door and keep most the cold air in the freezer.
So, how can the Ref side be cold and the freezer side not freezing?
1. Coolant leak. There is enough coolant to keep the Ref side cool but not enough to freeze on the freezer side.
2. Defrost system failure. The coils on the freezer side are clogged with ice and it's just a matter of time when the Ref side won't cool either. The back wall in the freezer will be covered with ice/frost
Posted on Jan 12, 2009
Sea Breeze
  • 4655 Answers
SOURCE: Refrigerator is somewhat cold as is the freezer
Your refrigerator has a defrost timer located near the floor and behind the kick plate. Remove the kick plate grill and turn the timer slowly clockwise until refrigerator compressor stops running. Leave it there for about 30 minutes or until refrigerator restarts. During this time the refrigerator should be in the defrost cycle. Open the freezer and you will possibly hear a crackling noise or the noise of water sizzling as it drips from the evaporator to the defrost heater. If your refrigerator does not restart after this time then turn the timer again slowly until the compressor restarts. If you do this then the timer will need replaced If no defrost takes place during this time then we need to move to the rear of the freezer and unplug the refrigerator and do some test on the defrost heater. Let me know how this worked out for you. The part number for your defrost timer is 10530703
Thanks, Sea Breeze
Posted on Jun 24, 2009
Have error code H1 on my freezer. I have it set on 5 what does it need to be
Frigidaire Refrigerator Error Code = H1
Condition = Freezer sensor shorted in freezer display
Repair or Check = Check wiring between thermistor and board. If correct, replace thermistor
Parts Needed = Thermistor (temp sensor)
Jul 05, 2017 | Refrigerators
My refrigerator shows a code "OF" or "0F" where the temperature settings usually show, we tried to put the temperature settings back but couldn't. We unplugged the refrigerator to reset it but it sti
Cooling Off mode (also called Shop mode), is designed for use by retailers when they are displaying refrigerators on the shop
floor. In Cooling Off mode, the refrigerator's fan motor and lights work normally, but the compressors do not run, and
the refrigerator and freezer do not get cold.
To start Cooling Off mode, Touch and hold the Energy Saver button and the Power Freeze button for 3 seconds during normal
operation.
The refrigerator chime sounds and the temperature display flashes OF OF.
To cancel Cooling Off mode, Touch and hold the Energy Saver and the Power Freeze buttons again for 3 seconds.
Source: http://downloadcenter.samsung.com/content/EM/201104/20110414114919054/110323-QS_Guide-POLARIS-EN.pdf
Dec 30, 2013 | Samsung Real Stainless Steel 30 Cu Ft Side...
Electrolux fridge temperature control displays a "square"
Try lower either the thermostat setting or the airflow control to the refrigerator to see if the temps are lowered.
Nov 26, 2013 | Electrolux Frigidaire Fridge Defrost Timer...
My Samsung model RB1855sl shows the temperatures for the fridge and freezer in celcius. Can you tell me what appropriate temps would be for them to be working? I loaded up with gorceries a few days ago,...
the freezer should be arond -20 degrees celcius and the fridge aroud 5 degrees celcius
There could be a problem with air flow
the fan in the freezer has probably stopped or the air flow into the fridge is probably blocked
You could have a defrost problem. this would allow ice to build up in the freezer blocking off ai flow.
A technician can help you with that
Mar 24, 2011 | Samsung RB2155 Bottom Freezer Refrigerator
Gaggenau fridge, freezer and cool-fresh does not freeze
did you ever manage to solve this problem. I'd like to know the solution because I am experiencing the same problem now.
Thanks
Bart
Apr 03, 2010 | Refrigerators
Refrigerator temperature showing lower than it is.
SOME OF THESE CONTROLS SWITCH TO CELCIUS. SOME DO IT ON ACCIDENT AND CANNOT BE SWITCHED BACK. LOOK AT YOUR BOOK. IF YOU HAVE NO BOOK GET IT FROM THE MANUFATURES WEBSITE. OR REPLACE CONTROL.
Mar 29, 2010 | Electrolux 25.9 Cu. Ft. Side-by-Side...
Fridgidare/Electrolux top freezer not freezing fan stays on.
Look for ice buildup on the back wall of the freezer.
If ice is there you have a defrost parts issue.
If not, check the compressor to make sure it is running.
Mar 04, 2009 | Electrolux Refrigerators
Appliance Outlet
Thanks,
Bill
Nov 10, 2008 | Frigidaire FRT15B3A Top Freezer...
Refrigerators Logo
19 people viewed this question
Top AEG Refrigerators Experts
Oscar Netto
Oscar Netto
Jim Goldsmith
Jim Goldsmith
ashburton
Are you an AEG Refrigerator Expert? Answer questions, earn points and help others
