20 Most Recent AEG S70408KG Bottom Freezer Refrigerator Questions & Answers
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
Self Cleaning Oven Problem
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
Asker's Testimonial " Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! " - amymrocks
AEG S70408KG... | Answered on Aug 18, 2010
You may have an issue with a defrost component (e.g.: defrost thermostat, defrost heater(s) or defrost timer). Contact an appliance service company.
AEG S70408KG... | Answered on Apr 14, 2010
The way to determine whether it's the thermostat or a refrigerant problem is to take note of when it shuts off. If you can hear the compressor running all the time then the thermostat is fine. If the compressor shuts off before the refrigerator gets cold then it may be a thermostat problem.
Before assuming it's a 'gas' or refrigerant leak I suggest you check the condenser coils, these are copper coils of tubing usually located on the back of the unit near the ground. They need to be free of all dust and grease to work at maximum efficiency and it is recommended to clean them every 6 to 10 months. If that doesn't solve the problem then there may be a refrigerant leak. In order to legally put reclaim, recharge, or test refrigerants you need a special certification2_bing.gif from the EPA. If you need to do so I recommend you call in a certified technician.
AEG S70408KG... | Answered on Mar 25, 2010
Well, the defrosting system is crapped out. Check defrost timer, defrost heater, and defrost thermostat to locate faulty component. Read more about diagnosing defrost system failures.
AEG S70408KG... | Answered on Nov 25, 2009
MAYBE,GO TO SEARS .COM CLICK ON PARTS PUT IN YOUR MODEL NUMBER AND SEE IF THEY HAVE YOUR PART,ALSO TRY REPAIR CLINIC.COM-MIKE
AEG S70408KG... | Answered on Dec 06, 2008
why do you want to put gas into your dehumidifier????????. this only needs to be done if there has been a leak and in that case you need to cure the leak first. you should use a vac pump as well to clear the charging line of gas. ideally, you should degas the appliance first and charge with the correct amount of gas.. the type of gas you need should be on the rating plate and is not necessarily r134a. gas goes in on the low pressure side and for this you can use either the charging stub (piece of pipe which is blanked off) or the low pressure pipe which is the larger diameter pipe of the other two. any refrigeration needs the correct amount of the correct gas.
AEG S70408KG... | Answered on Jul 04, 2008
Sounds like the drain pan or tube is frozen and clogged
You need to shut off the unit and empty the freezer section and check the bottom of the rear wall of the freezer for the drain pan.
use sink hot water to defrost and a turkey Baster to clean the hole and the hose.
AEG... | Answered on Jun 20, 2019
no gas or faulty compressor not worth repairing
AEG... | Answered on Feb 02, 2019
Possibly evaporator fan not working or defrost problem.
AEG... | Answered on Oct 05, 2018
You have very good door-seals,
with strong magnets on the refrigerator.
I suspect, You must pull hard to open the door.
Does the fridge have 2 wheels?
It may only stand firm on 2 "legs" and not 4.
This problem is the first, I ever heard,
I do not know this model,
If it is a Refrigerator that is not very heavy, this can happen.
When the door seals are very good, what can happen is
The door has been closed and the air inside the fridge becomes cooler and cooler.
The air inside the food-compartment contracts,
because it cools down and pulls even more on the inside of the door surface, actually pulling the door shut.
( a negative air-pressure inside the fridge) compared to
the outside of the refrigerator.
A trick I am using
is,
1.)
I place my finger between the door and the cabinet-frame.
2.)
Then, with the finger, index or middle finger,
I push gently
against the Door-Seal (Gasket).
for 1 or 2 seconds,
This allows the
Air from outside, (higher pressure)
to flow into the food compartment of the fridge
and now it is easy to open the door.
Let me know if this works for you.
Appreciate to be alive and be kind to others.
Klaus
(Electrical & Refrigeration Technician)
Toowoomba, AUS
AEG... | Answered on Feb 06, 2018
Request a service manual by contacting AEG directly.
AEG... | Answered on Jan 20, 2018
COULD BE THE PART CALLED AIR DAMPER MOTOR HAS FAILED call a service tech to test it .
AEG... | Answered on Jan 04, 2018
AEG S70408KG Bottom Freezer Refrigerator Logo
Popular Tags
15 questions posted
Top AEG Refrigerators Experts
Tony
Level 1 Expert
David Del Polito
David Del Polito
Level 1 Expert
Steve F
Are you an AEG Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
AEG Refrigerators
  • AEG Refrigerators
Most Popular Question
aeg s75380 similar like
  • Refrigerators
