My laptop suddenly stopped while working
SOURCE: driver for HP Pavilion DV6 for Inbuilt webcam Driver
Go to cyberlink.com download driver, you can also use Skype. Just remeber to check what version you have, this should be found in the manaul. Hope this helps
SOURCE: Low volume on my HP Pavilion dv6-1245
Open the audio panel (settings -> control panel -> Sounds and audio devices -> volume). Check that the volume slide is all the way to the right. Also, click on the "speaker volume" button and check it is all the way to the right
SOURCE: Hp pavilion dv6, laptop not
I'll bet it does have a system board, (Motherboard/mainboard)problem mraut80!
Want to see what the problem is, how to fix it, and info about recalls to HP?
(It's a problem that occurs with the Pavilion dv2000, Pavilion dv6000, and Pavilion dv9000 series of Notebook PC's)
http://www.youtube.com/watch?v=bnkQNmKauEc
SOURCE: i can not use my
Make sure the trackpad isn't disabled. HP laptops have either a button with an orange light illuminated when disabled or a light in the touchpad itself. Click the button, and it will turn white, indicating it is enabled. If it has a light in the touchpad, double tap the light and it will re-enable the touchpad.
